2016 Roadglide ultra no start
Old Jun 25, 2018 | 10:57 PM
Rupertultraroadglide's Avatar
Still fires up with gas into intake so fuel pump or ecm not telling pump to come on all fuses and relays good
Old Jun 25, 2018 | 11:27 PM
Mr. Mike's Avatar
Mr. Mike
By chance are there 2 relays alike you can interchange to prove their functionality - one controlling the fuel pump, and another?
Old Jun 25, 2018 | 11:46 PM
Yes checked both relays are good
Old Jun 26, 2018 | 12:50 AM
ke5rbd's Avatar
ke5rbd
Unplug the fuel line from bottom of tank and re plug. Make sure it snaps in. You may just push up on it and get it started. This is pretty common problem. This is assuming you can hear the fuel pump running. The fuel pressure regulator could also be faulty, but much less likely. ECM doesn't have a fuel pressure code. I think it will show no fuel pump voltage code.
Old Jun 26, 2018 | 04:15 AM
Kingglide549's Avatar
Kingglide549
You narrowed it dwn to no fuel.
Should be more EZ to diagnose.
I will suspect cam or crank sensor
Old Jun 26, 2018 | 05:23 AM
pjb's Avatar
pjb
What do the cam and crank sensors have to do with not getting fuel?
Do you hear the fuel pump initialize when the ignition is switched on?
I would also check the fuel line quick disconnect from the tank, as mentioned.
Old Jun 26, 2018 | 07:33 AM
Yes can hear pump also disconnected fuel line three or four times still no luck only when I spray gas into intake it starts fuel pump to come out next also pulling codes no communication to ecm
Old Jun 26, 2018 | 08:02 AM
Veekness's Avatar
Veekness
OP...looks like you're not making any headway on this, and the myriad suggestions you are getting here might have you chasing your tail. My contribution is to suggest that it's time to get your scooter into the dealership or an independent mechanic.
Old Jun 26, 2018 | 09:19 AM
Vernal's Avatar
Vernal
When you turn the Ignition switch on the pump runs for 2 seconds then turns off if the CKP does not show the engine is running. Once the engine starts to rotate the BCM turns the pump back on:
Originally Posted by Rupertultraroadglide
Bring up code loss of communication to ecm would that mean ecm fried
It's helpful to know the DTC number you pulled and if it was in the ECM, BCM or ABS...I'm guessing U0100. Did it clear and then come back?
Old Jun 26, 2018 | 09:29 AM
pjb's Avatar
pjb
I gave up trying to decipher his messages. No punctuation, or anything to make it make sense.
