Brake Fluid
Old Jun 28, 2018 | 08:17 AM
harfooz's Avatar
harfooz
Pentosin DOT 4 LV low viscosity is what most recently went in, and will be there until I can get the recall flush completed.
'fooz
Old Jun 28, 2018 | 08:39 AM
btsom's Avatar
btsom
Originally Posted by Cygnusx51
I bought a bottle of the Brembo Dot-4 from Auto Zone. It was plenty to flush the brakes and the clutch, running about 3-4 master cylinder fulls through each.
The supposed problem with home flushes is that the fluid in the ABS unit doesn't get changed. Think in terms of draining and refilling your gas tank several times. You now have very fresh gas in the tank, but unless you started and ran the engine for awhile, you still have old, original fuel in the fuel lines and injectors. Same idea with the ABS unit. What you have done is better than nothing, but in no way assures freedom from future failure.
Old Jul 3, 2018 | 09:28 PM
hardheaded's Avatar
hardheaded
I just received 2 quarts of BG Dot 4 brake fluid and was wondering if this would be OK to use in my trike ? The only differance i see is the BG stuff has a lower boiling point of about 30 degrees.
Old Jul 4, 2018 | 07:04 AM
alarmdoug's Avatar
alarmdoug
Originally Posted by RDHIGH
Im not sure what "premium" means when it comes to brake fluid. Price maybe?lol . I think ANY dot4 fluid would be ok- as long as its fresh. They all have to meet a dot4 specification.
EXACTLY ^^^
DOT 4 is DOT 4. The DOT does not recognize any other DOT 4, its just DOT 4, any words put in before or after DOT 4 is simply marketing.
Old Jul 4, 2018 | 07:34 AM
Flinter's Avatar
Flinter
I just rebuilt my calipers/flushed my system. I used Super Tech Dot 4.
Walmart..... $5.75 per quart. If I remember correctly, the dealer wanted $7.50 per pint.
Old Jul 4, 2018 | 09:19 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
There is no special recognition of DOT Platinum 4, only DOT 4.
'Nuff said.
Keep it sealed, flush it every couple of years, ride.
Old Jul 4, 2018 | 09:38 AM
ORradtech's Avatar
ORradtech
That's because all the DOT cares about is that their minimum standard be met. It does not mean there's nothing better out there. There is.
Old Jul 4, 2018 | 09:50 AM
Cygnusx51's Avatar
Cygnusx51
Yeah I activated the ABS, front and rear, after doing the flush. That should have pushed new fluid into the unit. There’s so much debate on this that you can’t take a definitive stance either way it seems. I’ll be sure to keep you updated if I ever have a failure.
Old Jul 4, 2018 | 03:05 PM
hardheaded's Avatar
hardheaded
Well there is some differance in the specs. between different fluids. They all meet min. Dot 4 standards but some have higher boiling points than others, HD's platinum happens to be one of them. That's what's going into my clutch.
Old Jul 4, 2018 | 04:24 PM
Joe from So Cal's Avatar
Joe from So Cal
Every time you start the bike the ABS cycles once. Granted, that may not be the same as cycling it 20, 50, or however many times a Digital Tech does it, but if a person changes the DOT 4 every 5k miles (very inexpensive when done at home) you're exchanging nearly new fluid with brand new fluid.
I bought a small inexpensive vacuum pump and it's easy to do. Just don't draw any air into the system.
