Intermittent CEL on ‘03 Road Glide
Old Jun 30, 2018 | 08:35 PM
John Aldridge's Avatar
John Aldridge
Stage II
Default Intermittent CEL on ‘03 Road Glide
Hello all.
As the title states, I’m getting an intermittent check engine light and normally it is when I am at highway Speed’s in 5th gear or if I downshift and throttle to pass somebody on a 2 lane road.
I have searched how to pull of the DTC’s and what I have found is the following. If I put a jumper across the pins one and two of the data link connector and turn the key to ignition a single flash will occur for four seconds then the light goes out for six seconds and then the light goes back on for four or five more seconds then the light goes off....THATS IT!
Next I removed the jumper and did the same thing, got the same exact results. What does this mean? Thank you very much and advance and safe travels.
John
Old Jun 30, 2018 | 09:57 PM
mmesa005's Avatar
mmesa005
Here is the complete "How To" for pulling DTC's from your model year.
https://www.hdforums.com/forum/softail-models/591458-how-to-diagnostic-trouble-codes-dtc-s.html
glider1993
May 20, 2020 07:21 PM
Casper
Aug 2, 2018 11:19 AM
panman4977
EVO
Jun 24, 2015 08:07 AM
dplantz
Oct 10, 2012 10:28 AM
mccstevie
Sep 17, 2012 11:30 PM
