95 Electra Glide
Old Jul 3, 2018 | 07:53 AM
Bertman's Avatar
Bertman
Stage II
Default 95 Electra Glide
I have recently perched 95 Electra Glide and I replaced the fuel lines on injection system . When I put everything back together the fuel pump dose not come on . I have retraced my steps 3 times . I have checked the fuses and the relay . I am new to this type of injection system . Do I need to prime it ?
Old Jul 3, 2018 | 08:02 AM
Veekness's Avatar
Veekness
As always with these situations, go back and check your work. If not successful, have somebody else check your work. Even if you have to pay for it.
And check your service manual for the correct procedure. Don't have one? Get one before you turn another wrench!
Old Jul 3, 2018 | 09:07 AM
grbrown's Avatar
grbrown
Wink
Hi from the UK and welcome to HDF. Your bike is an Evo and you may find it worth calling in on the dedicated Evo section. We have a few experts on that early EFI system over there - your bike is the first retail model Harley with fuel injection.
Old Jul 3, 2018 | 09:15 AM
14GuineaPig's Avatar
14GuineaPig
Try this link, it's for the 1995 & 1996 Wiring Diagrams & Electrical Troubleshooting Guide. It has a section on troubleshooting the EFI.
https://serviceinfo.harley-davidson....%3D1996+wiring
If the link doesn't work, goto the HD Service Info Portal and do a search for "1996 wiring", The troubleshooting guide should show up in the search results.
https://serviceinfo.harley-davidson.com/sip/index
Old Jul 3, 2018 | 01:39 PM
larsfum's Avatar
larsfum
Which fuel lines did you replace the internal or external? You said you checked the fuses. Did you also check the two fuses that are behind the right side cover? One is to the fuel pump. The other to the ECM. You don't need to prime it. That is what happens when the pump comes on for 3 seconds after turning the key switch and stop/ run switches on. If the fuel pump does not come on check the battery first. Then check for +12v at the yellow wire leading to the fuel pump under the console. It will only show +12v if the key switch is on, and the stop/ run switch is set to run, and only for 3 seconds. If you have +12v at the yellow wire then either the pump, or the connections to the pump are bad.
Old Jul 3, 2018 | 07:17 PM
mmesa005's Avatar
mmesa005
Did you pull the fuel tank? Check the connections at the base of the tank near the seat. There should be connections for the fuel gauge and fuel pump.
HiSpeedCam
Exhaust System Topics
May 28, 2026 11:42 AM
Mmmhoss
May 24, 2023 12:29 PM
Bertman
EVO
Jun 27, 2021 06:31 PM
floridabeach
Oct 25, 2008 04:10 PM
floridabeach
Oct 25, 2008 03:45 PM
