All,
After reading multiple post and watching a YouTube video, I was able to pull a few codes.
Im getting P0522/P0523 and U0184. Looks like I may be getting it towed to the dealer.
P0522 /P0523 are low and high oil pressure readings, respectively.
Hunt down your oil pressure sensor and check for damage or wiring issues.
U0184 is lost connection with boom audio. Could be low battery caused it or I read someplace that the BCM (body control module) could be at fault.
Having to take it 200 miles sucks but might be your best bet.
Good luck.
Although the battery does not seem fully charged, if it cranks...there should be enough juice for it to start.
My friends SG wasnt having any issues at all until we were set to ride one day. Bike turned on fine, all electrical worked, turned over with no hesitation but it wouldnt fire. No codes, no issues that we could find. Went to a local oil supply store thats also a Deka battery dealer to get a new battery as his was 6 years old. Bike fired right up and off we went.
That's not my experience, although admittedly with an EFI BMW. Darned thing would crank over just fine, but the max voltage the battery could deliver when fully charged had dropped from optimum and the fuel injection wouldn't kick in. The battery was around 11/12 years old, so a new replacement was an easy decision, after which the bike ran like a champ.
