Loose shift lever
Old Aug 9, 2018 | 10:00 PM
F150HD's Avatar
F150HD
Originally Posted by Veekness
The Grade 8 will stretch less than the OE Grade 3 or 5, I would imagine, and would tighten down the clamp better.
Thanks. see post directly above.
Old Aug 9, 2018 | 10:27 PM
hog95023's Avatar
hog95023
Originally Posted by Joe from So Cal
I noticed some play between the shift lever and the shaft. I pulled off the foot levers and shift lever and cleaned it all up.
It seems I can't get the pinch bolt tight enough to clamp down tightly on the shaft. The foot levers rock back and forth about a quarter of an inch. Is there a chance this was designed this way? Is this lever tight on the shaft on your bikes?
easy part to replace. Mine gave up the ghost near Salt lake City Utah. I use zip ties to hold it on as it kept wanting to vibrate off the shaft. rode 800 miles back home that day tied up that way.
Old Aug 9, 2018 | 10:32 PM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by F150HD
thanks, tried it to no avail. As this thread is about the front shaft lever and mine is about the rear shaft/lever I did post pics and video in a thread about the rear lever and shaft. Not sure if I have an issue or not. Details at post link below.
https://www.hdforums.com/forum/gener...l#post17582976
Believe me the repair I refereed to was for the lever which you indicate in your video ... The lever that attaches to the transmission shaft and not the shift linkage ...however yours was pretty screwed up for sure.
Old Aug 9, 2018 | 10:48 PM
F150HD's Avatar
F150HD
tried a grade 8, no difference. Unclear if the lever is moving on the shaft, or if the lever is tied to the shaft and it moves a bit.
Old Aug 9, 2018 | 10:49 PM
Joe from So Cal's Avatar
Joe from So Cal
That Buehler item is certainly pricey but if push came to shove I can see myself buying one.
Old Aug 10, 2018 | 07:01 AM
F150HD's Avatar
F150HD
but your issue isn't w/ that lever and shaft, correct?
Pulling primary would save $200. That's a new belt, nearly a new compensator....easily a new stator etc.
Price is a headscratcher. If they only wanted $50 for the part I'm guessing sales would jump. But for $200+ ??
Wonder what I;m missing on the price? I now nothing is free, but....
Old Aug 10, 2018 | 01:41 PM
Joe from So Cal
but your issue isn't w/ that lever and shaft, correct?.
That’s correct, front shaft with foot levers, the inside lever that actuates the rod connected to the rear lever.
The rear lever looks okay, but I’ll give it a close inspection when I pull the front assembly apart.
Old Aug 10, 2018 | 02:58 PM
hattitude's Avatar
hattitude
If that's the front, foot shifter lever, I'd pull that assembly apart. It's very easy to do. A ten minute job. Inspect the parts...
On some models, the lever is one piece, attached permanently to the shaft. If it's one piece lever/shaft, it could be the two bushings in the primary mount that need replacing. There's a Jim's tool that makes it a piece of cake to change/install them, or you can drive them out with a punch, and insert both new ones sandwiched between a bolt, two washers, & a nut.
If it's the type with a shaft and a separate lever, just get a new lever. They are not that expensive. Inspect the splines on the shaft. They should be fine as the lever is designed to wear before the shaft. However, if was loose long enough, you may need a new shaft. Again, not too expensive... And while taking it apart, see if there is a lot of shaft play between the shaft & bushings... might as well replace them while you are in there if they need it.
Either type, when you put it all back together, use a good, waterproof gease on the shaft where it rides in the bushings. Some say using ant-seize works better and lasts longer. I use grease and clean/re-grease on about a two year schedule.
One-piece shaft/lever:
Two-piece shaft & lever:
Old Aug 10, 2018 | 07:31 PM
Joe from So Cal
Mine is the two piece item.
As I said, I'll pull it apart again and give it a proper assessment.
What I won't do is cheap out and get stranded somewhere.
Old Aug 12, 2018 | 12:38 PM
Governor's Avatar
Governor
Stage IV
Been there myself Joe.
BAKER TRUSS STYLE SHIFT LEVER KIT. Forged instead of the cheap cast pot metal the MC uses.
