Loose shift lever
Old Aug 9, 2018 | 11:18 AM
DanHappy's Avatar
DanHappy
Welcome. Changed mine out a month ago. Do the shaft as well when your in there if its the front one. If the back one, then you dont.
Old Aug 9, 2018 | 12:09 PM
Flhr Rider's Avatar
Flhr Rider
Just changed mine out last week. Also noticed the shift lever on the transmission was sloppy to and it would not tighten up, removed bolt and replaced with grade 8 , 5/16 x 24 x 1, wrenched it down and good to go. Also used blue loctite.
Old Aug 9, 2018 | 03:25 PM
F150HD's Avatar
F150HD
This is where I;m at (2012 Ultra). After reading this thread, went out and did some more disassembly and inspection (50k on bike), lever on the shaft is a little sloppy (about to post another thread on it).
What exactly did the new bolt do that the original bolt did not?
my bolt looks fine, unclear how replacing bolt would help, esp if the splines on the lever itself are chewed up a little (not that that is the case but....)
Old Aug 9, 2018 | 03:31 PM
Uncle Larry's Avatar
Uncle Larry
The original ( existing ) bolt doesn't want to torque any further ... Removing the old bolt, chasing the threads ( not using a tap ) with a new bolt and a bit of lubricant. Cleaning the threads with a bit of brake clean followed by a new bolt with a bit of Loc-Tite torqued to specs will generally ( I've done this with great success on several scooters , even out on the road ) tighten it up and give extended service
Old Aug 9, 2018 | 03:51 PM
F150HD's Avatar
F150HD
Thanks. You using a HD bolt as replacement? or Grade 8 from hardware store?
Def worth a try. Dont want to pull entire primary to replace if I can help it.
Old Aug 9, 2018 | 03:56 PM
Uncle Larry
Grade 8 from hardware store will do the trick
Old Aug 9, 2018 | 04:36 PM
klammer76's Avatar
klammer76
As Uncle Larry said, get a new hex bolt, grade 8 will work. Put a small sae flat washer under the head, lube or anti seize on both sides of the washer. Blue loc tite on the threads and tighten it down tight. If that doesn't work, new shift arm. You can trim some off the slot of the arm making it slightly wider thereby allowing it to clam a little better. The arm is aluminum, the splined shaft is steel. The arm will wear before the shaft. Only in an extreme case would you have too address the shaft.
Old Aug 9, 2018 | 08:21 PM
Veekness's Avatar
Veekness
The Grade 8 will stretch less than the OE Grade 3 or 5, I would imagine, and would tighten down the clamp better.
Old Aug 9, 2018 | 09:12 PM
Joe from So Cal's Avatar
Joe from So Cal
Originally Posted by AliensilverFXDBI
I had a '12 street glide that had this issue.
replace the socket head capscrew with a regular grade 8 hex head bolt. Then before installing use a vise or hammer and pinch the gap shut. It was a BITC H to get it perfect but eventually I got it to slide on with virtually zero play then loctited and tightened the PI$$ out of the bolt. Did it with the primary installed. Was tight until the day I sold the bike 17k later.
This is what I was thinking of doing. The grade 8 bolt is a good suggestion. And just to be clear, it is the forward shaft with the foot levers on the outboard side, not the other one behind the primary cover. Also, the splines looked good but I need to check even closer again.
While I've been wrenching on cars for about 45 years now I'm new to HD and crazy as this may sound, I wasn't sure if they engineered it this way. Thanks for all the suggestions and comments!
Old Aug 9, 2018 | 09:58 PM
F150HD's Avatar
F150HD
thanks, tried it to no avail. As this thread is about the front shaft lever and mine is about the rear shaft/lever I did post pics and video in a thread about the rear lever and shaft. Not sure if I have an issue or not. Details at post link below.
https://www.hdforums.com/forum/gener...l#post17582976
