small leak
Old Aug 20, 2018 | 08:23 AM
jerryleejr's Avatar
jerryleejr
Default small leak
Had my bars swapped and used a +3 clutch cable. Now the exhaust bracket under the cable housing is staying wet. I’m assuming they didn’t use a new gasket or O-ring when they did the swap. I’m gonna take it back to the shop and hopefully it’s an easy fix. Never fails I’m a week out from a long trip.
JJ
Old Aug 20, 2018 | 08:29 AM
PDB17UltraRG's Avatar
PDB17UltraRG
That’s when it happens good luck you get it fixed enjoy your trip
Old Aug 20, 2018 | 10:40 AM
jerryleejr's Avatar
jerryleejr
thank you, I’m more concerned that either the shop can’t get to it in time or they try and say it wasn’t their fault...
JJ
Old Aug 20, 2018 | 11:53 AM
acchd's Avatar
acchd
The exhaust bracket bolts loosening up causing trans fluid leak is not uncommon. I had mine work loose once. I cleaned up bolts used some locktite and re-torqued no issues since.
Old Aug 20, 2018 | 01:11 PM
jerryleejr's Avatar
jerryleejr
so you think it’s not a gasket issue?
JJ
Old Aug 20, 2018 | 01:26 PM
Kingglide549's Avatar
Kingglide549
This is something you cant address?
Old Aug 20, 2018 | 01:39 PM
jerryleejr's Avatar
jerryleejr
had you read the thread yes it’s in the shop getting addressed, however it seems there may be other causal factors outside a gasket or O-ring but glad to see you building your post count...
JJ
Old Aug 20, 2018 | 02:17 PM
acchd's Avatar
acchd
JJ
Not sure but here are 2 bolts that work themselves loose sometimes causing trans leak. Tightened them up normally cures issue.
https://www.google.com/search?q=harl...wxAhoXxhKYL3M:
JohnTz
Milwaukee Eight (M8)
21
Nov 2, 2018 11:09 PM
teddiec1
Sep 25, 2018 09:00 AM
ironmike666
Engine Mechanical Topics
14
Jun 24, 2018 06:00 PM
23Seven
Jun 18, 2018 01:48 AM
davidsdad
Jan 13, 2012 03:28 PM
