so my bikes an 08 EG that i turned into a street glide no tourpack any more
i had the lepera bara bones solo seat witch i liked the position it moved me back and down but a local guy was selling a '15 street glide seat i like the looks of it so i bought it installed it on my 08 and fist ride i noticed the bike felt different, i felt like the bike was more stable more predicable the ride felt a little smoother (might be seat padding not sure?) in sweeping turns its more planted
does rider position have that much to do with handling or is this just me sitting with extra pad under me im not feeling as much? the reason i ask is this SG seat moves me up a few inches and now i feel to close to the fool controls and my knees are bent more so legs are not as comfy
Owned a 2004 RK and took a test ride on a 2009 when they came out. Harley changed the frame that year and I can tell you it made a huge difference in the handling and the vibration. If your 2015 doesn't have the crummy rear air shocks that would be an improvement as well. Not sure how they changed the front forks so someone would have to comment on that.
I just changed the stock seat out for a Corbin Classic Solo. First thing I noticed was how the bikes handling changed. Its like it lost 200 lbs. Much Much better handling. It feels much less top heavy.
It has to be the seating position.
You better believe it does. Try going around a curve at speed, see how much lean angle is needed. Keep centered on the seat. Now try it while scooting to the inside of the seat edge, and you'll need less lean angle at the same speed. We call it "body English". Usually only used at high speeds, since at lower speeds, normal lean angle is sufficient.
Those crotch rocket racers don't hang off the edge of the seat and drag their knees on the pavement for kicks. Riding position definitely effects handling. In your case, you have changed the center of gravity slightly and possibly the load on the shocks. Probably not enough to really tell the difference. My guess in your case it's simple muscle memory. For example, you could probably reach out without even thinking about it or looking and grab your grip. Now it's moved so it's not in the same place and feels different. I bet that's the kind of things you are feeling more than the handling. You're old bike that fit like a glove isn't the same glove anymore. It will just take some time to relearn the muscle memory of where everything is now.
Seat position or your position in the seat can also affect handling. Look at cop motors. They sit very close to the tank and sit well forward of where most of us casual riders sit. The VSP believe this position enhances the handling of the bike.
