clutch cable needed
Old Aug 27, 2018 | 06:00 AM
rsaunders1's Avatar
rsaunders1
Stage I
Default clutch cable needed
what clutch cable would i need to install 12" Paul Yaffe monkey bars on my 2013 streetglide
Old Aug 27, 2018 | 06:10 AM
Iceman24's Avatar
Iceman24
Nice welcome & I'm sure mods will move this to the correct "Touring" forum. Might want to take time to learn this site & give a proper greeting in the "New Member" section.
As far as cables for your ride, it's a matter of comparing the difference in height/reach fm old-to-new bars. If you want a few good sites to to learn/source this info, go to sites like LA Choppers & Hill Country Customs.
https://lachoppers.com/
https://hillcountrycustomcycles.com/
Old Aug 27, 2018 | 10:54 AM
Spartanden's Avatar
Spartanden
i believe if you look in the parts and accessories catalog, there are sections in the back that show different lengths of cable.... figure what your stock cable is and the extra length you need on your set-up and check that out. Find the stock length, tape measure your new set up and go from there. if you haven't yet installed anything, I did a bunch of calculating in my Sportster when I changed bars.... looked at dimensions of stock and the bars I wanted, checked length of stock cable, measured and moved forward. The key is the extra length of the new bars....
Old Aug 27, 2018 | 04:42 PM
dawg's Avatar
dawg
+6 should work just fine.
hellboundslim
May 11, 2017 03:16 AM
Daddio
Feb 7, 2012 09:56 AM
Chunker
Jun 22, 2011 07:19 PM
MangoMike
Jan 26, 2010 09:19 PM
dc3plt
Dec 7, 2009 03:23 PM
