??True Duals Question??
Old Jun 29, 2007 | 01:29 PM
Elder51's Avatar
Elder51
Default ??True Duals Question??
My new '07 Ultra is sched for 1000 mi. in a week....
during this time they are going to install V&H Ovals, V&H FuelPak, & a new air system
The question is.... Should I also do a set of "True Duals"... Main interests are general engine performance as the type ride the "Ultra" is.... Good Harley sound (not LOUD, but deep, throaty, oh we all know how it's supposed to sound), &cooler (so far no outrageous heat issues [West Coast Fla])
And what brand Duals and why?
THANKS
GOOD GOLLY MISS MOLLY....WE LOVE THIS RIDE!!!
TO THINK WEMISSED IT FOR25 YEARSRIDING ONGL's!!!
Old Jun 29, 2007 | 01:32 PM
dagnabit9's Avatar
dagnabit9
Default RE: ??True Duals Question??
I think you will get the desired effect (sound, less heat, better performance) with just what you have going on there. Unless you're trying to keep the heat off your thighs, the True Duals might be a bit much IMO. I installed what you have (or are going to have) and I couldn't be happier..
Old Jun 29, 2007 | 01:51 PM
SoCal_Pappy's Avatar
SoCal_Pappy
TD's WILL reduce Heat better then OEM!!!
Seeing as you're going the V&H route - They do make a very nice Dual header set-up
I did the slip-on route... Took the Grandson for a Putt this week - Temp was 90+ in places & some minor stop & go traffic. I raised pass floorbrds raised to the top mount- Have RJ's and he was still saying his right leg was getting a little hot... Now thinking about doin' the duals also SOON
Old Jun 29, 2007 | 02:13 PM
Silverearl's Avatar
Silverearl
I started with the slip-ons and decided to add the TD's I have not regretted it yet. I have over 17K on the 06 that is 1 year and 2 days old..
Old Jun 29, 2007 | 02:14 PM
mlgoheen's Avatar
mlgoheen
do the true duals at the same time, you will be sorry if you don't
Old Jun 29, 2007 | 02:27 PM
Wags1's Avatar
Wags1
If your main interest is performance than you don't want true duals. Generally speaking they will perform worse then your stock headers and certainly worse than a 2-into-1 setup. I have nothing against true duals. However, you should just be getting them for the right reason, sound, and a cooler right leg...not performance.
Bagger07
Oct 19, 2007 12:44 PM
tcartwr332
Aug 17, 2007 02:55 PM
cabbage
Jun 11, 2007 02:59 AM
lottinala
May 8, 2007 09:42 PM
koga
Feb 2, 2007 06:48 PM
