Should I have changed speakers also?
Old Sep 20, 2018 | 02:17 PM
No Tyme's Avatar
No Tyme
Default Should I have changed speakers also?
I upgraded to a Harman Kardon radio in my 05 Electra Glide. If I understand correctly the 05 radio ran 4 ohm speakers and the Harman Kardon runs 2 ohm speakers...
So I need to either replace the speakers to 2 ohm or add an amplifier with 4 ohm output correct?
Not wanting to spend a lot of money to continue this upgrade but a pair of speakers can easily set me back a hundred. Anyone have recommendations on an amp?
Looks as if either way I am spending more money.
Old Sep 20, 2018 | 02:41 PM
Fireball Jack's Avatar
Fireball Jack
well first off what is it exactly is your goal? Are you trying to replace all four speakers? If it is stock 2 OHM speakers you want I have a set of four on my shelf. I will ship to you for 15.00 plus the ride.
Old Sep 20, 2018 | 03:37 PM
Jetblack3's Avatar
Jetblack3
Jump over to audio section and ask there, you'll get excellent guidance from that group. Yes you will totally want to upgrade speakers to a larger 6.5 inch with adapters and an amp. Can easily do for a few hundred and you'll be much happier.
Old Sep 20, 2018 | 03:55 PM
No Tyme's Avatar
No Tyme
Thanks, I have Hog Tunes in there now but Iron Cross says the ohms on the speakers are different from 05 to the HK radios.
OldPhat
2014-2024 Touring Models
Nov 5, 2017 11:45 AM
Jersey Drew
Audio Systems
Apr 9, 2017 09:23 AM
wevsspot
Audio Systems
Jan 22, 2016 09:48 PM
bob53
Nov 6, 2011 02:05 PM
omahairishfan
Jun 3, 2007 02:36 PM
