New clutch needed.
Old Sep 30, 2018 | 07:11 AM
  #31
vistavette's Avatar
vistavette
Originally Posted by Scudda
I change mine out this year with teh Energy One extra plate and heavy duty spring kit..Love it.....
@ pieces of advice if you go with energy one.....They recommend B&M trick shift trans fluid..use it
and when adjusting the clutch only back off the adjuster a 1/4 turn
is 1/4 turn within spec? I seem to recall the service guide as 1/2 to 1 one full turn. I personally use 1/2 turn which puts engagement in the middle of the lever travel. It would seem that 1/4 might casue some drag....or do I have it reversed, where 1/4 put it way out toward the end of lever travel?
Old Sep 30, 2018 | 10:36 AM
  #32
RickW3's Avatar
RickW3
I wonder if my clutch might have been adjusted to tight before. Would grab with just a little release of the clutch lever. Now releases much farther out, with less initial grab. Maybe I might try to adjust it with a little less backing off of the adjustment bolt. When I adjusted it, I turned out between 1/2-3/4 turn.
Old Oct 9, 2018 | 04:06 PM
  #33
RickW3's Avatar
RickW3
I finally was able to ride with the old lady, and find that my clutch works properly. Might have been adjusted a little on the tight side. Now that I know it is all good, time to ride.
SkurtBob92
Sep 19, 2021 09:14 PM
1Felix1
Aug 24, 2018 04:06 PM
hardheaded
May 8, 2018 02:57 PM
Smoothie54
May 4, 2018 02:30 PM
Velocity1
Jul 28, 2013 08:35 AM
