1983 flht upgrade
Old Sep 29, 2018 | 10:24 AM
gus58's Avatar
gus58
Default 1983 flht upgrade
Im removing and storing the original shovel motor in my flht and fitting a 93 s&s shovel motor. Is there any chance of a later model gearbox and primary fitting? Id like to get away from the original older style starter but I think I’d have to use a splined instead of tapered gearbox to do that? Maybe theres a simpler answer? Cheers...
Old Sep 29, 2018 | 10:59 PM
gus58's Avatar
gus58
No one? Maybe I should put it another way..... will a rubber mounted twincam primary and gearbox fit behind a rubber mounted shovelhead?
Old Sep 30, 2018 | 08:40 AM
0ldhippie's Avatar
0ldhippie
No...
Old Sep 30, 2018 | 09:04 AM
nobodyknowsme's Avatar
nobodyknowsme
You might consider contacting Baker. They may have some ideas that would work for you, at least ideas of a direction you could go with your bike.
https://bakerdrivetrain.com/products...nt=16092460803
Old Oct 1, 2018 | 04:45 AM
gus58's Avatar
gus58
I want to get away from the weak starter motor, maybe later evo style?
Old Oct 1, 2018 | 06:08 AM
grbrown's Avatar
grbrown
Wink
That's a better possibility. I suggest you also ask in the Evo section, where there are plenty of our experts on the older models. All twincam transmissions bolt up to the engine in a different way to Evos and shovels.
gus58
Engine Mechanical Topics
Jan 14, 2019 01:38 AM
bentparts
Dec 26, 2017 02:14 PM
jadev
Jun 18, 2008 09:37 PM
larry5h
Oil Archive (no new posts)
Mar 26, 2007 03:13 PM
steventh
Exhaust System Topics
Jan 13, 2007 10:26 AM
