Front End Wobble
Old Sep 29, 2018 | 11:02 AM
mtbottles's Avatar
mtbottles
Default Front End Wobble
2018 Ultra Limited Front End Wobble on deceleration. I had the failed wheel bearing wobble on my previous bike. This is not the same.
This happens specifically on a straightaway while decelerating. In second gear, bring the RPM to just above 3000 and release the throttle. Have my hands lightly touching hand grips. When the RPM drop close to 2000, front end begins to wobble violently.
Front tire air pressure is on the low side 32 PSI. Will add some air and see if it still happens. Meanwhile I made an appointment for service.
Any ideas?
Old Sep 29, 2018 | 11:04 AM
Kevin714's Avatar
Kevin714
I'd check the motor mounts, but being a new bike...take it to the dealership.
Old Sep 29, 2018 | 11:13 AM
Juice's Avatar
Juice
Yes, Dealership warranty.
Could be a loose neck bearing?
Old Sep 29, 2018 | 11:15 AM
IdahoHacker's Avatar
IdahoHacker
Originally Posted by mtbottles
...Front tire air pressure is on the low side 32 PSI. Will add some air and see if it still happens. Meanwhile I made an appointment for service.
Any ideas?
32 psi is NOT "on the low side." It is dangerously low. In addition to causing poor handling, it will cause accelerated tire wear, and probably cupping as well.
Get both front and rear tire pressures set correctly, and let us know if that helps.
Old Sep 29, 2018 | 07:04 PM
pointblank's Avatar
pointblank
Mine WAS wobbling when I applied the front brakes so I got some new brake rotors and it went away.
Old Sep 29, 2018 | 07:11 PM
doghead's Avatar
doghead
Symptoms sound like neck bearings loose. Ask your dealer to do a fall away test, and correct it if needed.
Old Sep 29, 2018 | 07:13 PM
PDB17UltraRG's Avatar
PDB17UltraRG
Air pressure is way to low maybe knock it out of balance get it back to your dealer.
Old Sep 29, 2018 | 08:06 PM
CSMHOG's Avatar
CSMHOG
for a 2018 it’s not a fall away, it’s a swing back and your symptoms suggest just that.
Old Sep 30, 2018 | 06:33 AM
oldhippie's Avatar
oldhippie
Any ideas?
At what speed is this? If it's 38 down to 20 it is perhaps the tire. Especially with Avons and some of the more aggressive profile tires.
Old Oct 1, 2018 | 06:31 PM
mtbottles's Avatar
mtbottles
Stock tires: Front should be 36 and they were 32. Added correct air pressure and still had the same problem.
Service appointment for Thursday.
