01 ultra classic problem
Old Oct 1, 2018 | 07:50 PM
Gmtapke's Avatar
Gmtapke
Stage II
Angry 01 ultra classic problem
all
have an 01 ultra. All stock. 98000 mile. Runs good up to 55 mph. Over that it seems to starve for fuel
if you open the throttle, it takes right off till it levels out to hold speed. I have replaced wires, plugs and tested the coil.
Any one have any ideas?
Old Oct 1, 2018 | 08:00 PM
ORradtech's Avatar
ORradtech
If it acts starved for fuel I'm unsure why you went to plugs and ignition...
Things that come to mind are fuel filter, fuel lines, fuel pump.
Is it injected or carbed?
Old Oct 1, 2018 | 08:18 PM
Gmtapke's Avatar
Gmtapke
Stage II
Default Fuel injected.
Just trying everything
Old Oct 2, 2018 | 05:00 AM
grbrown's Avatar
grbrown
Red face
That can get expensive, if you don't diagnose the problem! Another suggestion is the internal fuel line, inside the tank, which is known to give problems when it springs a leak.
Old Oct 2, 2018 | 02:38 PM
hattitude's Avatar
hattitude
Both "grbrown" and "ORradtech" bring up good points. It's very expensive to throw parts at a problem without doing some solid diagnostic work first.....
It sounds more like a fuel problem than an electrical one..... Have you done any recent work to the fuel system?
I would check the fuel filter/internal tank fuel lines, as "grbrown" suggested, if it's EFI. That is a well known problem, where the internal fuel line leaks due to rubbing/vibration, and certainly possible on a 2001 bike with 98K miles. Also, if it's EFI, you should have the MM EFI system, which may be in need of adjustment. There are a few threads on this forum that mention how to dial it in..
If it's a carb bike, check the "filter" (screen on the petcock inside the tank) for debris, or an inline filter if one was added. You may just have some accumulated junk in the tank, partially blocking that screen/filter, so enough fuel flows for low rpms, but is restricted for higher flow/rpms.... Another issue with some of the older tanks (happened to my 2001), the tank liner/paint that the MoCo used, starts peeling and coming off in chunks... it will partially block the screen @ the petcock and cause intermittent fuel starvation. Also if it's a carb bike, there is a vacuum action to the OEM petcock that will not allow fuel to flow without vacuum from the carb... check that vacuum line for cracks, etc...
There are a lot of things to check, before swapping out any parts.... I'm sure you will get other suggestions I have not mentioned
Good luck with the fix......
Old Oct 2, 2018 | 09:51 PM
Firebike32's Avatar
Firebike32
Could it be starving for air?
Old Oct 2, 2018 | 10:11 PM
run1fsr's Avatar
run1fsr
Okay, you've taken a few basic steps ... no harm in that. But yes, appears to be fuel related.
Same question: Fuel injected or carburetor?
ZachN09
General Topics/Tech Tips
Oct 16, 2018 08:18 PM
XRoads
Oct 8, 2018 08:46 AM
jkhawaii
Jul 6, 2018 10:26 AM
Race freak
Aug 13, 2011 07:04 PM
roadking1550
Apr 11, 2011 01:02 PM
