slip ons leaking?
Old Jul 1, 2007 | 02:05 AM
atexn4christ's Avatar
atexn4christ
Default slip ons leaking?
I noticed that my Rush's are leaking today. Do they all leak or should I crank down the bolts? They gotta come of to chage tires right.
Old Jul 1, 2007 | 02:13 AM
streeter's Avatar
streeter
Default RE: slip ons leaking?
The Torca (muffler clamp)clamps are a one time use only. Put some high temp RTV on the pipe before you install the muffler and torque the clamps down to spec. Good luck!
Streeter
07 FLHX
Old Jul 1, 2007 | 03:22 PM
choochoo's Avatar
choochoo
look at the clamps. THe ends pinched up against the inner wedge?
If so time to replace.
You can use stock ones or after market t-bolt full circle clamps.
J&P and other sell them
If you use silicone use it sparingly and use the high temp orange or high temp black.
But let the tuner know you did that if you go in for a tune.
It can damage the o2 sensors they use for tuning.
Old Jul 2, 2007 | 02:14 AM
atexn4christ
Thanks the t bolt clamps look alot better than the stock ones. I will order some right away.
Old Jul 2, 2007 | 02:20 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: atexn4christ
Yes they look better but just so you knowthey don't clamp down as well/tight as them big ole stock Torca clamps. The stock Torca clamps are double the thicknessof the aftermarket T Bolt clamps, thus resulting in being able to really tighten them down on the exhaust.The Torca's are too big for me to use on my Bassani Road Rage 2-1 pipe or i would have them on there.
Old Jul 2, 2007 | 02:11 PM
Manish_Hawg's Avatar
Manish_Hawg
The Torc clamps don't last forever, but I have used mine 4 times with no issues.
Old Jul 3, 2007 | 06:46 PM
norskehd's Avatar
norskehd
[:@] Had the same problem when I installed a set of HD SE Performance touring mufflers - took them off and installed new clamps - no leaks now.
Old Jul 3, 2007 | 07:15 PM
Longtimegone's Avatar
Longtimegone
FYI ... the Torca clamps are the best available for clamping with even pressure around the circumference of the pipes. They do have a limited life, but only cost a few bucks to replace.
Old Jul 3, 2007 | 10:23 PM
choochoo's Avatar
choochoo
I've used the T-bolts for years and so has the trucking industry. Good quality ones will tighten down more than you would think from casual observation.
And being full circle seem to be even better at sealing
Old Jul 3, 2007 | 10:27 PM
hogdad's Avatar
hogdad
No they don't all leak. No they don't have tocome off to change a tire.
