Exhaust
Old Oct 5, 2018 | 09:20 PM
Boobie504's Avatar
Boobie504
Stage III
Default Exhaust
I have a 2017 SGS the slip on right side keeps getting loose. This is my first harly. Is this a common problem?
Old Oct 5, 2018 | 09:39 PM
run1fsr's Avatar
run1fsr
Stock Exhaust ... no.
Old Oct 6, 2018 | 07:59 AM
purpledeuce's Avatar
purpledeuce
Could be the muffler clamp. Also make sure the bolts (under the saddle bags) are torqued properly
Old Oct 6, 2018 | 08:35 AM
nobodyknowsme's Avatar
nobodyknowsme
We can only guess it is the clamp that is coming loose, and I presume the bolt but can you confirm? If that is the case, blue loctite should help you out.
Interesting username...
Old Oct 6, 2018 | 02:45 PM
Boobie504's Avatar
Boobie504
Stage III
Default Okay il try
[QUOTE=nobodyknowsme;17736534]We can only guess it is the clamp that is coming loose, and I presume the bolt but can you confirm? If that is the case, blue loctite should help you out.
Interesting username...[/ I don't think that's it
Old Oct 6, 2018 | 04:13 PM
Ed Ramberger's Avatar
Ed Ramberger
Torca band clamps shoud really only be used once per most manuals, but we all use them over. However, they get to a point where you think they are tight but will allow the muffler to slip back. If the band clamp is tightened to spec and it still occurs - replace the clamp.
Old Oct 7, 2018 | 08:46 AM
purpledeuce
good advice, cheap insurance too
Old Oct 8, 2018 | 07:51 PM
talkingrock's Avatar
talkingrock
It’s usually a bad clamp causing the problem
DynaDaego
Exhaust System Topics
Jun 10, 2018 09:13 AM
smoen81
Aug 14, 2012 12:18 AM
Adam_T
Sep 28, 2009 03:07 PM
nasoscia
Shovelhead
Jul 28, 2009 01:21 PM
Sporty12C
Aug 31, 2006 06:51 PM
