Speedometer problem.....
Old Oct 11, 2018 | 04:28 AM
Dronk's Avatar
Dronk
1st Gear
Default Speedometer problem.....
Hi
Bought and installed the 70900071A speedo and the installation process worked out fine with no problems. Everything works (almost) Speedo ok, Tach ok, Clock ok, Gear ind ok, lights and so on, BUT! not the odometer part. My dealer controlled the ECM but everything look allright so we changed to a new speedometer with the exact same result.
Do someone have clue what the problem could be? Have an 07' Road King Classic.
Thanx
Anders, Sweden
Old Oct 11, 2018 | 06:23 AM
RANGER73's Avatar
RANGER73
https://serviceinfo.harley-davidson....1?locale=en_US
says you need to do a data link upload for the odometer to work
Old Oct 11, 2018 | 07:10 AM
Dronk's Avatar
Dronk
1st Gear
Done that! That is not the problem.
Old Oct 11, 2018 | 07:24 AM
btsom's Avatar
btsom
Still have the original speedo to see if the odometer updates on that one? In anything that is mass produced, it is possible to have the same malfunction in several or all units. While not likely, it is possible there is a production run of these new speedos with the same factory error. I would think that the big Harley computer would be able to determine if the proper data is being sent to the new speedo for running the odometer. Do the turn signals still cancel automatically?
Old Oct 11, 2018 | 09:21 AM
Dronk's Avatar
Dronk
1st Gear
The old speedo was/is totaly dead so it is not possible. The dealer read the ecm but could not see anything wrong. Turn signals are still cancel automatically.
After installation you have to drive for about 42km or so before the speedo are "merried" to the ecm and that countdown did work on the tripmeter. (On both speedos) After that no signs of life...... :-(
Old Oct 11, 2018 | 06:48 PM
RANGER73's Avatar
RANGER73
Just asking if you watched the video? It shows you have to plug it into a connector under the seat near the battery
until it reads OK before you plug it into the speedo harness.
Ryan Lee Brasher
Electrical/Lighting/Alarm
Jun 24, 2014 09:07 PM
THEXFILES
Sep 12, 2013 12:29 AM
Poacher13
Apr 13, 2011 06:18 PM
shake rattle n roll
Mar 28, 2010 01:36 AM
gdw70
Sep 13, 2005 02:52 AM
