Does anyone know what type of plug the accessory plug in the fairing of a 2017 SGS is? This is the 2 pin plug up by the voltage gauge. I need the female pins/connector to use as switched power for an amp.
I trying to find out what the female connector is that plugs into it. it does not appear to be a molex or a deutsch connector. I'm looking for the connector type so I can buy it at DigiKey. It may be a TE Amp connector 174463-1 but I'm not sure.
Both housings were on my bike; I just needed to buy the contacts.
Thanks for confirming that, This is the same as this one from Digikey for anyone needing just pins. It does appear that the "blank" that is in it just needs the pins to be functional. https://www.digikey.com/product-deta...0Interconnects
I know this is a 4-year-old thread, but I just found the Harley part numbers. The male plug is sold by Harley as the 73152-96BK. The pins are 73191-96. These are for if you're trying to wire up an accessory to plug into the existing female plug, or if you use the 2-way splitter 69200921.
