bcm code
Old Jan 3, 2023 | 10:37 AM
Woodrow Miller's Avatar
Woodrow Miller
Default bcm code
So I put pro beam signals up front and all in one custom dynamics plate set up out back on my 15 rg. All led. So I am getting the code 62151 at the bcm and it clears no problem. then comes back after riding. Lights all work as they should except the dash signals are fast. I tried the custom dynamics sync method off there site but no change. Any help on how to fix it or sync it all . Thank You
Old Jan 3, 2023 | 10:59 AM
CoolBreeze3646's Avatar
CoolBreeze3646
b2151
B2151 Left rear turn signal output open. Check the signal to ensure it is working maybe a loose wire or wire abraded under the fender or seat area.
Old Jan 3, 2023 | 11:02 AM
Woodrow Miller
Default Bcm help
I will check
it out for any loose or tight , pinched etc.
Old Jan 3, 2023 | 02:27 PM
MRFREEZE57's Avatar
MRFREEZE57
Installed a set of LED signals on the front of the RGL, they flash at normal interval but the indicator lights flash rapidly and get a code also, have tried everything they say do do and to no avail, guess just have to live with it.
Old Jan 3, 2023 | 02:46 PM
Woodrow Miller
Default Bcm code
Exactly my situation it im
gonna go over the rear set up to be sure
dontdropit
Aug 26, 2021 11:40 PM
dansflhti
2014-2024 Touring Models
Aug 27, 2014 09:12 PM
Vanstreetbob
Dec 24, 2013 01:13 AM
Fathertime500
Jan 21, 2013 04:34 AM
Bdhouse61
Jul 28, 2011 09:12 PM
