Jackshaft
Old Nov 7, 2018 | 06:43 PM
Jack3512's Avatar
Jack3512
Stage IV
Default Jackshaft
2003 Dyna Wideglide - Transmission case broke, replaced tranny, everything back together, starter noise when trying to start, pulled off outer primary cover to visualize, Jackshaft is getting stuck (not returning all the way) and yes the coupling is in correctly and the bearing seems ok. looks like an alignment problem,but there is no adjustment with clutch basket when installing? just put it on and torque to 80 lbs, any idea before I pull clutch hub and starter? Thank You very much for any insight as your time is greatly appreciated. Keith
Old Nov 7, 2018 | 08:25 PM
F150HD's Avatar
F150HD
________________
Old Nov 7, 2018 | 08:53 PM
Schex's Avatar
Schex
Don't overtighten the jackshaft bolt, back it off, just snug it, bend the lock tab.
Old Nov 8, 2018 | 12:55 AM
nytryder's Avatar
nytryder
I had a similar problem on an early Dyna. I machined about twenty thousands off the starter gear and all is well. I never could decide what happened. Original problem was belt replacement. I did not do the belt replacement but was able to repair the starter gear problem. Hope this helps.
Old Nov 8, 2018 | 05:53 AM
0lowrider1's Avatar
0lowrider1
I have a 01 fxdl.it gave me a problem , this one time.I removed the outer primary cover and found the bushing that the Jacks shaft rides in was scored pretty bad.its a brass bushing.I replaced it,put some oil on it and its been great ever since.also great advice to just snug the Jack shaft bolt then bend the tab.might want to get a new tab as it has a rubber seal on it.
Old Nov 8, 2018 | 08:49 AM
Jack3512's Avatar
Jack3512
Stage IV
Thanks for the tip, took a fine file to Pinion gear along with loosining the jackshaft bolt and it now works great. Thanks again
NELS
Oct 27, 2016 10:11 AM
ridefast91
Feb 16, 2015 11:28 PM
oakmossy
May 23, 2014 05:32 PM
ACE75
Jun 11, 2007 01:19 AM
3boogitys
Feb 13, 2006 08:36 PM
