? starter drive
Old Oct 27, 2016 | 04:36 AM
NELS's Avatar
NELS
Default ? starter drive
Putting my buds '01 low inner primary back together and noticed the starter drive/jackshaft is always engaged. Is this correct? On my '08 Dyna it is recessed until you engage the starter. Never noticed this before and need some experienced help. Thanks in advance.
Old Oct 27, 2016 | 07:17 AM
jdvorchak's Avatar
jdvorchak
don't know on the 01 but my brother in law 04 the starter gear is retracted and not in constant contact like you describe. Did you forget a space behind the clutch basket? Does the primary chain line up with the compensator teeth?
Old Oct 27, 2016 | 07:44 AM
NELS's Avatar
NELS
Thanks for the reply, I took it apart and found the spring behind the gear wasn't seated properly. My fault.
Old Oct 27, 2016 | 10:11 AM
jdvorchak's Avatar
jdvorchak
Don't beat yourself up. You were smart enough to ask on the forum here before you did something really stupid....Glad you got it sorted out.
arod6
May 13, 2016 07:46 AM
el loco rico
Apr 15, 2013 03:01 PM
RoadRich2010
Jul 31, 2012 09:52 PM
foush56
Jan 30, 2012 11:14 AM
Joker441
Shovelhead
Feb 8, 2006 04:56 AM
