Best lowering method?
Old Dec 20, 2018 | 06:23 AM
DonnieM's Avatar
DonnieM
You have got good advice, addressing the rear shocks would be the best solution, but it involves more coin spent
I have the same inseam, and used the Pingel 1 inch lowering kit with no problems. Always wear boots and you should be ok
Old Dec 20, 2018 | 08:10 AM
heybaylor's Avatar
heybaylor
Originally Posted by Jonny Rotten
Does it make sense to mess with the lowering blocks at 1 and 2 inches to get a feel for what I need before thinking about dropping $700 on some of these shocks? Seems like it would.
Also if the lowering blocks gets me to where I want I'm assuming its a done deal and theres no need for shocks at all?
Whats the benefit of mixing new shocks and blocks if the blocks gets you low enough on there own?
The ride is fine as the bike sits with the stock 13" shocks .Never bottomed out
Lowering with blocks alone and riding 2 up is my concern with bottoming out.
when you move the shock mount farther from the swingarm pivot the shock becomes stiffer with the same springs.
it will ride stiffer, and put more stress on the shock bolt.
this is copied from Bitchen baggers website
  • Changes critical shock angle causing rough ride.
  • Stability issues and increased bagger wobble.
  • Can cause the lower shock eyelet to break off.
  • The brackets often times break from flex and fatigue caused by increased shock angle.
  • Clearance issues with bags due to increased shock angle
  • Allows tire to come in contact with fender, VERY UNSAFE, if you're lucky it only burns up your tire, the paint on your fender and the tail light wiring harness.
Old Dec 20, 2018 | 09:28 AM
Sethc1020's Avatar
Sethc1020
Originally Posted by Guntoter
This is Bitchinbaggers.com site, but now it's just numbers. Call them to make sure they are still in business. But they will lower your existing air shocks to wherever you want them for a lot less than new shocks. They do great work, if they are still in business.
http://162.243.65.160/products/drop-shocks/
Might end up going this route. Has anyone tried the Progressive 412 shock? How does it ride? In not going to spend $750 on the 444s just to lower the bike down about an inch.
Old Dec 20, 2018 | 10:33 AM
Sethc1020's Avatar
Sethc1020
Actually after doing more reasearch I may end up going with the LA Choppers 1" lowering kit. Its designed different than all the other kits I've seen and does not change the angle of the stock shock. Part # LA-7590-00B. Anyone used these?
https://www.ebay.com/itm/LA-Choppers-Rear-Lowering-Kit-1-Drop-Black-LA-7590-00B/352437391790?_trkparms=aid%3D111001%26algo%3DREC.S EED%26ao%3D1%26asc%3D20160908105057%26meid%3Db7330 01af9e14a6b80d8c6ce20847309%26pid%3D100675%26rk%3D 1%26rkt%3D15%26sd%3D352437391790%26itm%3D352437391 790&_trksid=p2481888.c100675.m4236&_trkparms=pagec i%3Acc66fe1d-0474-11e9-a882-74dbd1806ab5%7Cparentrq%3Acc75c8181670ab6771bb9ff1 fffb83bf%7Ciid%3A1
Old Dec 21, 2018 | 09:17 PM
08 S Glide's Avatar
08 S Glide
Lowering blocks are a bad idea. Your fender will be one inch closer to the tire. Your shock will still have the same amount of travel. Fender could hit the tire.
Old Dec 22, 2018 | 06:40 PM
hog dog 82's Avatar
hog dog 82
6th Gear
Hey 95th 1200 is that MKS Custom Upholstery out of Slinger Wisconsin?
Old Dec 22, 2018 | 07:11 PM
Sethc1020's Avatar
Sethc1020
Well I ended up going with a different seat from a 2016 street glide. Its the low seat so hoping that will bring me down as far as I need to go. If not will probably send it in for a Mod.
Old Dec 22, 2018 | 07:29 PM
Cozz's Avatar
Cozz
LA Choppers kit is the cat’s ***. I run the 1” lowering blocks. No issues, no problems, after 3 years. They are very beefy and maintain stock shock angle. Don’t even think about the 12 dollar style, they look like junk.
Old Dec 22, 2018 | 07:47 PM
almostakeeper's Avatar
almostakeeper
I've had the L A Choppers lowering blocks on for 4 1/2 years with 0 problems.
No shock angle change
No bottoming out, and I have a full dresser + a passenger
No death, destruction or dismemberment.
I've also done the MCC to narrow the stock seat up
Old Dec 23, 2018 | 07:16 AM
fabricater's Avatar
fabricater
I Use The LA Chopper rear lowering blocks on my 2012 ultra limited. They do not change the shock angle and work with no problems. I ride 2 up and luggage is full with a tour bag on the luggage rack. Those who say rear lowering blocks change the shock angle have not seen the blocks made by LA Choppers. My dealer recommended them for a 1" drop. They are well made. I agree that the cheaper blocks that move the shock bottom back could be a problem. I used progressive lowering springs in the front to lower it 1" and used a lighter weight fork oil. I have stock seat and a 28" to 29" inseam and can flat foot the bike. This is the best riding bike I have ever had. ( I have had 5 different goldwings) The bike does drag easy,but I tend to push it a little harder in the turns than some.I don't consider myself aggressive but moderate rider. I know 1" does not sound like much,but it is a big difference when sitting on a bike.
