Torque Caliper Bolts
Old Dec 8, 2018 | 10:16 PM
23Seven's Avatar
23Seven
Default Torque Caliper Bolts
Time to wise up and use a torque wrench.
I was washing my bike today and discovered a missing bolt on my rear caliper the other bolt was backed out about a 1/2 turn as well.
I changed out my wheels and put new pads on over a month ago and went with my usual feels about right torque values. I believe I dodged a bullet catching this missing bolt before the other one backed out as well.
I split lanes daily in bumper to bumper traffic and brake failure especially a caliper getting jammed in a wheel in traffic could be fatal.
Picking up a new bolt and an inch pound as well as a foot pound torque wrench. Does no good reading torque values in a manual and then buttoning everything up without the wrench.
If you’ve been wrenching without a torque wrench learn from my mistake and do it right!
Old Dec 8, 2018 | 10:40 PM
IdahoHacker's Avatar
IdahoHacker
If you want to do your own work, even as simple as changing your oil, you need a torque wrench. It's not up for discussion.
Glad you got one, and glad your caliper didn't end up in your lap!
Old Dec 8, 2018 | 11:04 PM
23Seven's Avatar
23Seven
Live and Learn... Glad I learned my lesson without losing any skin!
Old Dec 8, 2018 | 11:44 PM
Sam2010's Avatar
Sam2010
last time I had a bolt back out of a brake caliper ruined the threads on the caliper bracket.
Old Dec 8, 2018 | 11:46 PM
IKnowNot's Avatar
IKnowNot
Good post to let others know of your (common) mistakes, so others don’t make them.
It is a bad idea to assume one can “feel” proper torque unless you do it regularly with a torque wrench, and then it is a mater of both experience and perception, especially with inch-pounds.
Also, did you apply the proper loctite?
Old Dec 9, 2018 | 01:59 AM
23Seven's Avatar
23Seven
Nope... I’ll be putting some blue on them tomorrow when I tighten it back up.
Old Dec 9, 2018 | 03:38 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
In my youth it was a case of doing up fasteners until they creaked and then back them off half a turn. I use a torque wrench now to remove the guess work.
If the screws don't show signs of having Loctite and the manual doesn't call for Loctite then just be careful of the torque you put on the fastener if you do put Loctite on it.
I didn't know until I found it here and also found it by a little research that the lubricating effect of Loctite will make the fitting tighter than it needs to be.
Old Dec 9, 2018 | 07:50 AM
sixguns's Avatar
sixguns
The problem with Torque wrenches is trusting one that has gone out of calibration, that is a recipe for disaster. So, If your willing to step up and do your own maintenance, you really should go all the way and maintain your tools. Have periodic calibrations done, because an out of calibration torque wrench is the most dangerous tool in your toolbox!
Old Dec 9, 2018 | 08:19 AM
1340hog's Avatar
1340hog
A quality torque wrench is a precision instrument and needs to be handled and used with care,but they all need calibrated in time.I have good(maybe not the best) inch pound and a foot pound torque wrenches that are used for the Harley only. I figure the less I use them the longer they will go before needing calibrated.Could I afford this?Not really but I can't afford a crash and burn on the highway either.I refuse to pay over priced steeler to do the work. A fallen off caliper on a motorcycle would be a disaster for sure.
Old Dec 9, 2018 | 08:31 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Blue Loctite is your friend along with proper torque.
