Run/Stop Switch
Old Dec 14, 2018 | 07:55 AM
Inop's Avatar
Inop
Did your map load from the FP3? if I recall the off/run switch is used to restart the ECM to load a new map
Old Dec 14, 2018 | 08:59 AM
grbrown's Avatar
grbrown
Further to all the good advice above, does your bike have non-stock handlebars, or have you disturbed the handlebar switches recently? It is all too easy to damage a wire and cause an electrical problem that way, which may be intermittent.
Old Dec 14, 2018 | 12:34 PM
Rogue8Man's Avatar
Rogue8Man
Thanks for all the great advice. Mr Brown in regards to your suggestion about the bars, they are stock; I think I am the only one in the universe who finds stock bars comfortable. For those who say remove the FP3 should I re-flash the stock map? Thanks
Old Dec 14, 2018 | 01:26 PM
Inop's Avatar
Inop
This is not making sense. In order to load the MAP from the FP3 the off/run switch needs to be in the run position. I would trace the wire from the switch to the connector and see if there is continuity.
Old Dec 14, 2018 | 01:38 PM
Super Glidester's Avatar
Super Glidester
Man, rip that injection off and put a carburetor on it...
Old Dec 14, 2018 | 02:34 PM
ange d mange's Avatar
ange d mange
Does the bike start with the run switch in the off position?
That might indicate switch problems.
Old Dec 14, 2018 | 03:59 PM
Rogue8Man's Avatar
Rogue8Man
Yes the bike does start with the bike in off position. Tried the original map with V&H rep on the phone and it did the same thing. Starting to think it was just coincidence the switch went the day after I installed the FP3...
Old Dec 14, 2018 | 05:27 PM
grbrown's Avatar
grbrown
Talking
You and me too!
Old Dec 14, 2018 | 05:41 PM
GalvTexGuy's Avatar
GalvTexGuy
He's talking about the engine off/run switch, not the ignition switch. The ignition switch is what's used to program/load maps on the FP3.
Old Dec 14, 2018 | 10:13 PM
Rogue8Man's Avatar
Rogue8Man
Followed the directions to a “t”. Thinking it the switch at this point.
