Run/Stop Switch
Old Dec 15, 2018 | 11:44 PM
Inop's Avatar
Inop
Originally Posted by GalvTexGuy
He's talking about the engine off/run switch, not the ignition switch. The ignition switch is what's used to program/load maps on the FP3.
Ahh, you have to have the ignition switch on for the off/run switch to work. Where did I post anything about the ignition switch?
Old Dec 15, 2018 | 11:56 PM
hbsoldier3's Avatar
hbsoldier3
Originally Posted by Infadel
Did your map load from the FP3? if I recall the off/run switch is used to restart the ECM to load a new map
This is not making sense. In order to load the MAP from the FP3 the off/run switch needs to be in the run position. I would trace the wire from the switch to the connector and see if there is continuity.
You never did mention the ignition switch. The whole point is you do not use the off/run switch to load an FP3 map.
Old Dec 16, 2018 | 04:39 PM
Rogue8Man's Avatar
Rogue8Man
Yes sir you are correct. Switch in “run” position and use the ignition switch.
Dudepants
Jan 22, 2018 10:22 AM
mixham
May 15, 2016 08:19 PM
ThisIsCrazy
Sep 10, 2013 09:48 PM
TheBlackBastard
Nov 19, 2011 07:53 AM
bfgoodmudder
May 3, 2010 12:00 AM
