need a v-h / big sucker map
Old Jul 4, 2007 | 12:30 AM
rickxx's Avatar
rickxx
Default need a v-h / big sucker map
greetings. just bought an 07 sg and i'm adding pc along w/ vance and hines basic slip-ons and a big sucker a/c. kinda surprised that map isn't on the pc website. anyone have this setup and a good map? thanks
Old Jul 4, 2007 | 12:56 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: need a v-h / big sucker map
You can always give them a call & they will recommend the best one for you mods...
Or pick the closest set-up...
ECM: Stock
SE: Air
V&H Slip-Ons
http://www.powercommander.com/powerc...31&yr=2007
Should be Map: M812-003 - But you can check to verify??
Old Jul 4, 2007 | 05:45 AM
rickxx's Avatar
rickxx
thanks. i did call 'em. that's the one the guy suggested but he wasn't sure. the only reason he suggested it was because it was a config with v/h pipes.i don't know how different those pipes are from the basics. you guys here are pretty good about sharing info so i thought i'd check with you all as well. i downloaded the other slip-on maps w/ se a/c so i'll try those if 812-003 doesn't work out. i guess i should have bought the pc from fuelmoto. if anyone has my set up and has agood map....
Old Jul 4, 2007 | 06:17 PM
rickxx's Avatar
rickxx
i went to the pc web site and saw a map w/ my setup (v-h basic slip ons, se a/c) but the map is for an 06....my bike is an 07. potential problems?
DonCMcC
2014-2024 Touring Models
Mar 18, 2015 06:47 PM
chfcheese
May 4, 2007 01:37 AM
BadBobOk
Apr 27, 2007 05:36 PM
t_m34
Feb 10, 2007 11:37 PM
Anthony8858
Nov 13, 2005 10:51 PM
