Changing Handlebars
Old Jan 13, 2019 | 02:12 AM
Malazan's Avatar
Malazan
Default Changing Handlebars
I was thinking about changing bars and was wondering at what length is it usually necessary to lengthen your cables?
Is it mostly a concern for Apes, i am looking a non Ape bars by the way. Something like the Wild 1 550 Beach Bar, or the 504 Dresser
i ride a 2018 Road King with stock bars right now
thank you
Old Jan 13, 2019 | 03:03 AM
duglaura&flhti's Avatar
duglaura&flhti
thank you
Depends on the height of the Bars you want? Style? Make?
Before I replace my second bars (Tall Boy) I had sat on a few different bikes during Gettysburg Bike week, so I had a idea and style, but most important height the bars I want....Yaffee 10' was the call and never looked back...only had to changed my clutch cable out....Good luck
Old Jan 13, 2019 | 05:49 AM
grbrown's Avatar
grbrown
This question is one of the regulars which pops up often! Some bar brands will answer your question for you, or offer the extra parts needed for the installation, such as wire extensions and longer cables, etc. Alternatively select your preferred bars, install them, then measure up what you need to give the finished result you will be happy with. There are too many options, on bar shape and geometry, to give an absolute answer IMHO.
Old Jan 13, 2019 | 09:15 AM
nutsandbolts5212's Avatar
nutsandbolts5212
I have the Wild 1's Beach bars on my RKC, needed wire extensions but not for the brake/clutch lines. I've done several bar swap jobs, 10-12" apes on all touring bikes, and I've concluded that my rule of thumb is anything more than 12" you will need to change the brake/clutch lines and wire extensions. I tell my customers to go with the longest on the wire extensions (15") so that that portion of the job is already done if they want to go taller.
The beach bars on the RK look bad ***! You'll like them!
Ride safe!!
jb1023
Aug 7, 2018 09:05 AM
crimson13
May 10, 2014 07:56 AM
desertwolf
Jun 19, 2013 01:09 PM
jknappy54
Jul 16, 2012 06:25 PM
ndotken
Nov 23, 2006 03:41 PM
