Why all the apparent problems finding neutral?
Old Feb 1, 2019 | 09:54 AM
  #31
hbsoldier3's Avatar
hbsoldier3
The shifter pawl is no longer adjustable, not since 2001 (2000 on Softail).
I thought it was pre-2007, and the OP has a 2006. However, would not be the first time I was incorrect.
Old Feb 1, 2019 | 10:13 AM
  #32
TSheff's Avatar
TSheff
Originally Posted by Scarydog
Neutral is easiest to find during hard acceleration while showing off and shifting to second gear...
Proper break in, oil level and adjustments have always help me the most.
You didn't think a REV limiter was on there to limit speed did you. Along with finding neutral so many just can't find gears.
Old Feb 1, 2019 | 10:20 AM
  #33
Tom84FXST's Avatar
Tom84FXST
A primary chain that is too tight, will always make for a hard to find neutral...
Old Feb 1, 2019 | 10:55 AM
  #34
dickey's Avatar
dickey
The early TCs had a problem shifting from 2nd to neutral; in fact the owners manual said it couldn't be done, you hadda shift down to 1st, then up to neutral. It COULD be done if you were careful, then sometime around '06 they came out with a free fix. (free; imagine THAT!)
Old Feb 1, 2019 | 11:53 AM
  #35
TheGrandPoohBah's Avatar
TheGrandPoohBah
I believe it is technique.
If someone just stomps at it, and expects it to go to neutral every time, just think about it.
When I want neutral, I have a heel or toe on the foot board, and with a controlled rocking motion I ease it into neutral, from first or second into neutral does not matter which. I just about always go from second to neutral every time I stop at a gas pump.
When I rode metrics, I just had to develop a feel for toe shifting into neutral. Foot on the peg, and again, using a rocking motion.
I am not surprised that "Stomp And Hope" often does not work.
Old Feb 1, 2019 | 12:58 PM
  #36
Crabchuck's Avatar
Crabchuck
What's the mechanical explanation for that? I don't see how it could be related.
Old Feb 1, 2019 | 12:59 PM
  #37
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Just looked at the service manual for my 04, and there's no adjustment. Different set up.
Old Feb 1, 2019 | 01:41 PM
  #38
pjb's Avatar
pjb
you can't see how the primary chain is related to the clutch/transmission?????
Old Feb 1, 2019 | 01:49 PM
  #39
JakeC7R's Avatar
JakeC7R
LOL that has been me more than once! DOH!!! Hilarious.
Old Feb 1, 2019 | 02:30 PM
  #40
tcatnat's Avatar
tcatnat
Yep, new bike issue mostly. I've had a bit of trouble on every new bike I've owned. Not enough to complain about but after a few hundred miles it becomes seamless.
