Pushrods
Old Feb 13, 2019 | 07:43 PM
ntraindavefl's Avatar
ntraindavefl
Yes you can adjust Andrews pushrods w OEM tubes. It’s just a little tight on space to work them.
Old Feb 13, 2019 | 08:40 PM
RANGER73's Avatar
RANGER73
^^^^This^^^
The S&S kit comes with new tubes because the adjustment portion is high up on the rod.
Old Feb 13, 2019 | 09:35 PM
hattitude's Avatar
hattitude
Originally Posted by skydude426
It’s true that removing the rocker box cover and rocker plate is more work than using pushrods that can be adjusted with the tubes in place for just a cam change. My point is that it can be done.
I've always gone through the rocker box for pushrods. If I can't use the OEM pushrods, I'll measure with a pushrod measuring tool, and then order the custom size from Smith brothers... What can I say, I like one-piece pushrods... and it really doesn't take that much more time...
While I have the rocker cover off, I upgrade the umbrella valves (on older twin cams) and do the rocker arm mod for increased oil return to the sump..
Old Feb 15, 2019 | 12:51 PM
skinman13's Avatar
skinman13
I am using SE adjustable push rods and went with aftermarket covers because the push rod instructions called for different covers. I could not find any chrome MoCo ones so I went with Colony, I think.
g1625s
EVO
18
Mar 9, 2019 07:23 AM
Nickd2689
Apr 26, 2018 01:42 AM
TO34
Exhaust System Topics
Feb 14, 2012 06:31 PM
jpooch00
EVO
Dec 5, 2008 06:30 PM
