Tire Pressure
Old Mar 5, 2019 | 07:33 AM
btsom's Avatar
btsom
Heat is the enemy of tires. Lowering tire pressure to "improve" ride will lead to tire failure due to heat build-up.. What's worse, a bumpy ride or a BLOW OUT?
Old Mar 5, 2019 | 08:01 AM
grbrown's Avatar
grbrown
Tyres are part of the suspension system! If you are very light-weight it would be wise to lower pressures a little, just as a very heavy rider should increase them above stock. H-D has failed to provide good guidance on tyre pressures in all the 40+ years I've owned them. On your RGS you could replace your short stock shocks with a pair off a taller model, such as an RG, to get more suspension travel and an improvement in comfort. Otherwise bin your shocks and buy some good quality custom-built ones - you will be amazed at the transformation!
Old Mar 5, 2019 | 10:00 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Look on your tires for the max inflation numbers. They can vary from what is posted on the bike frame.
If I am riding solo, I might go a couple or so psi below the max, when 2 up I go near or at the max.
If it's just a short solo ride, I often just leave them at the 2 up setting.
The Dunlops I ride is a very hard tire, others may vary.
If you have not yet, I encourage you to discover the best method for checking tire psi, both at home or away. For me at home, my bike goes up on the jack, in neutral so I can spin the rear wheel, with my creeper beside it. I have an air hose reel suspended in the garage where I can grab the end and take it anywhere I need it in or around the garage. Quick connects are a must. I have a Campbell gauge, trigger, and hose that fits my spoke wheels perfectly. While there, I can check, add, or take away psi as needed all in one. Simple.
Away, I have a Topeak 90 degree adapter for the rear wheel that will work on any air chuck that I keep on the bike. I also carry a small Slime Digital Compressor with a straight end that fits the spoke wheels easily, set the psi to what you want, turn it on, and it cuts off when the psi is reached.
I remain vigilant about my tire psi. I have TPMS via my Zumo GPS that shows my psi on the fly, and low psi alarms that lets me know if there is a problem. On the Zumo it also shows a graph about psi fluctuations during your ride. Yep, it might even report the time to you that you ran over a nail!
As you can tell, I am particular about my tire psi. I check all my vehicles about once a month, always having to add some during the winter. As for my cars and trucks, psi's stated on the tires are close, but in time you will notice what works best for you based on the old trusty tread depth gauge.
I want my tires at the best psi for greatest tread life, traction, safety, and comfort so I can ride with confidence.
https://www.amazon.com/Inflator-Inflation-Campbell-Hausfeld-MP600000AV/dp/B0007ZJ1IK/ref=sr_1_2? https://www.amazon.com/Inflator-Inflation-Campbell-Hausfeld-MP600000AV/dp/B0007ZJ1IK/ref=sr_1_2?
keywords=Campbell+air+gauge&qid=1551801421&s=gateway&sr=8-2 keywords=Campbell+air+gauge&qid=1551801421&s=gateway&sr=8-2
Old Mar 5, 2019 | 12:00 PM
sampansam's Avatar
sampansam
Thanks for the replies. I have been using factory specs for pressure. This bike replaced my 1980 FLT Tourglide which I bought new, the comfort level was quite good, The Roadglide handles great but bumps feel like a jack hammer. Any recommendations for aftermarket suspension? Perhaps a balance between comfort and handling?
Thanks again,
Sam
Old Mar 5, 2019 | 12:09 PM
Gary1's Avatar
Gary1
Thanks again,
Sam
My dealer recommended Legends, but they are little higher $$$ than Progressive.
Old Mar 5, 2019 | 12:18 PM
SWThomas's Avatar
SWThomas
Thanks again,
Sam
I went with customized Ohlins shocks in the rear and fork cartridges in the front. Got them from Howard at Motorcycle Metal. It was a dramatic improvement over the stock HD junk.
Old Mar 5, 2019 | 01:15 PM
Gary1's Avatar
Gary1
From what I have read is you need 13" shocks in the rear. The 12" oem shocks are part of the problem.
Old Mar 5, 2019 | 01:30 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 with Gary1, the 13" shocks will give you a little more travel, and don't feel bad about this, HD did the same thing to the StreetGlides to lower the stance of the bike, but harsh ride to driver and passenger.
Old Mar 5, 2019 | 05:20 PM
HD32141's Avatar
HD32141
Originally Posted by Dynamick
Welcome to the ride characteristics of the 12" Harley rear shock. .
Yep. I put 13" Ohlins on my SGS, and a 2" lowering kit. BIG difference.
I run 36 front always. 38 rear solo and 40 rear with a passenger. It's easy for me to adjust, I have a compressor and air reel in my barn.
Old Mar 5, 2019 | 08:42 PM
langwilliams's Avatar
langwilliams
you said you have the shocks set up for a soft ride....could it be too soft an you go right to the bump stops on a sizable bump?
