Lifter Question
Old Mar 5, 2019 | 07:09 PM
702's Avatar
702
Default Lifter Question
2000 TC88
Doing some work, and when I pulled the lifters out I was a bit puzzled. If you look at the picture and see the blue paint marks, the 2 lifters on the front cylinder had the paint marks facing outboard, and the rear cylinder had the exhaust lifter mark facing outboard, and the intake lifter mark facing inboard. Someone has been in the cam chest, as it has the Screaming Eagle hydraulic tensioner cam plate/oil pump conversion in it. If the answer is in the manual, I can't find it. Any idea what's going on here?
Old Mar 5, 2019 | 07:14 PM
Screamin beagle's Avatar
Screamin beagle
The manual says the feed hole on the lifter should face inboard.
Old Mar 5, 2019 | 07:17 PM
Screamin beagle
Oh yeah and you should consider making those lifters into paper weights and get some s&s standards.
Old Mar 5, 2019 | 07:21 PM
dawg's Avatar
dawg
Perhaps someone marked them as they took them out so they could put them back in the same position.
Old Mar 5, 2019 | 07:37 PM
702's Avatar
702
That's odd. With the antirotation pin in place, the hole either faces forward or rearward. I'll see what happens when the new lifters get here.
They're coming with the new cams.
Old Mar 5, 2019 | 07:39 PM
702's Avatar
702
After 50 years of wrenching and seeing very strange things, they probably did, then installed them wrong anyway.
Old Mar 5, 2019 | 08:13 PM
ROCKOUT Rocker Products
Sponsor
Lifter orientation doesn't matter, they can go in either way. If putting old ones back in try to get them in the original hole/direction
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 5, 2019 | 08:16 PM
702's Avatar
702
Thank you. I assumed the bleed hole didn't care what direction it was pointed, but better safe than sorry.
Old Mar 5, 2019 | 10:09 PM
Screamin beagle
Only matters if you follow the manual...ive read different opinions on the orientation.
Old Mar 6, 2019 | 06:12 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Good video on why to discard the harley lifters, like Screaming Beagle said:
Ride safe!
Stump juice 09 ultra
Engine Mechanical Topics
Feb 22, 2016 09:19 AM
Tim_Sr
Jul 20, 2014 08:10 PM
PHA-Q
Exhaust System Topics
11
Aug 18, 2011 02:00 PM
ionhd
Mar 3, 2011 10:42 AM
sniper77
13
Dec 22, 2009 05:21 PM
