LED Tail Light Replacement
Old Mar 29, 2019 | 10:46 PM
eaglefan1's Avatar
eaglefan1
I have the custom dynamics tail light and its bright as hell. When I installed it I put the box in that controller the amount of times it blinks, whatever its called. Been 2 years and works perfectly. Last month I added the vertical lights that go on the rear facia. If you don't see my brake lights now, then nothing will help. Its on the edge of being obnoxious, which is a good thing
Old Mar 30, 2019 | 02:25 AM
bklynbob's Avatar
bklynbob
Sound Off Signal Ghost Brake/ Tail light mounted on airwing rack.
Old Mar 30, 2019 | 05:38 AM
todd-67's Avatar
todd-67
I have the Harley LED tail light. I like it. You can't go wrong with it, the Custom Dynamics or the BAD light. All good choices.
Old Mar 30, 2019 | 05:42 AM
Mikes145's Avatar
Mikes145
I love my Bright *** Light on my Ultra.
Old Mar 30, 2019 | 06:08 AM
wagsrk08's Avatar
wagsrk08
I went with Custom Dynamics on my 2016 FLHTK Limited lighting wants. Pro Beam LED tail light, FillerZ, and front blinkers. Lifetime warranty and FANTASTIC customer service. Very easy instructions w/video support for plug & play on most items. You won't be disappointed!
https://www.customdynamics.com/
Old Mar 30, 2019 | 06:19 AM
KYRGultra's Avatar
KYRGultra
Yep, Custom Dynamic for me also. I have a 2016 RGU, CD makes a plug & play HD replacement all LED tail light and it is now available with their newest Probeam design. It ain't cheap at $159.95 (I think) but I think I'm gonna also get the CD plug & play controller so I can have the tail light strobe/pulsate but the CD controller will not work on the HD OEM non-LED tail light. And you can get the HD replacement tail light from CD in either the standard or layback, with or without window for license plate, red lens or smoked, etc. I already have the CD controller to strobe/flash my tour pak lights and I love it.
Old Mar 30, 2019 | 10:38 AM
Steve N,'s Avatar
Steve N,
I know that you asked for a 'direct replacement', but you might want to give the HD's lay back a second look. It's shaped to match the contour of the rear fender, and to me, makes the stock style look more like an add-on that sticks out. I don't know if you've considered smoked lenses along with your LEDs, but I think it's a nice upgrade as well. Of course this is just my opinion, and not necessarily yours. Regardless, you're going to be happy with your LED lighting. It's a game changer for see and be seen.
Old Mar 30, 2019 | 10:43 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by btsom
https://www.brightasslights.com/
Expensive but no one has ever regretted the purchase.
Yep ... I have to agree the Bright *** Light is fabulous.
https://www.brightasslights.com/site/
Old Mar 30, 2019 | 10:55 AM
Indawynd's Avatar
Indawynd
Yes. My BAL2 is insanely bright.
Old Mar 30, 2019 | 12:17 PM
hattitude's Avatar
hattitude
Originally Posted by aaa1988
Look at Custom Dynamics. Worth every penny
I own/use both....
I have the BAL-1 on two of my bikes and the Custom Dynamics GEN II Squareback LED tail light on one.
They are both quality units..... They are both much brighter than OEM...they are both easy installs...
The BAL-1 costs a little more, and has some built-in fancy flashing sequences you can choose from, as well as 3 brightness levels. The reason I tried the Custom Dynamics is because I don't care about, or use, all the fancy flashing options.... so I thought why pay for all that, and I saved about $50 on the CD light...
I don't think you can lose with either choice...
Bottom line for me is:
If you want a dependable, bright LED replacement light and want to be able to control multiple aspects of the light, with numerous different flash patterns, get the BAL-1.
If you just want a dependable, bright LED replacement tail light, save $50 and get the Custom Dynamics..
IMHO.... the BAL-2, while it probably can be seen from outer space, in my mind is way too expensive and bright to the point of being obnoxious... I want people to see me, not to **** them off....
