which tpms would you buy
Old Apr 9, 2019 | 07:01 PM
  #51
QNman's Avatar
QNman
Originally Posted by MotoJockey
So my questions are, on the Fobo's, can you listen to bluetooth music on you headset while monitoring your tires? Just wondering if the 2 different bluetooth signals will interfere with each other. And do you have to have the app up and running on the screen at all times or can it run in the background while riding and listening to music or nav, or when you stop and and want to check email or texts? It must use a lot of phone battery if it has to be on and running up front all the time. If it runs in the background and sends an alarm to my headset when a tire gets low, that would be cool.
I only noticed the Fobo when it dings at me. I listen to music via Bluetooth, and I almost never have the screen open unless I want to check the readings. I have never noticed a difference in battery between my bike and my car, which has no Fobo.
I hope that answers your questions.
In the interest of full disclosure: the batteries in the actual Fobo (2032's) seem to last a year or less, especially if left in the Fobo's over the winter in my unheated garage.
Old Apr 9, 2019 | 07:25 PM
  #52
MotoJockey's Avatar
MotoJockey
Thanks QNman, that DID answer my questions. The only thing I have to get past is how ugly that are on wheels, but.......... the Fobo's look a lot better than some that I've looked at, lol.
I looked at the pricing for the Bike 2's and the cheapest I found, (refuse to use Amazon because of Bezos), is actually the Fobo site itself.......$99/set with free shipping. eBay was like $110-120!!
Last edited by MotoJockey; Apr 9, 2019 at 08:49 PM. Reason: Found different prices.....
Old Apr 10, 2019 | 09:36 AM
  #53
QNman's Avatar
QNman
I am right there with you on Amazon! Bezos can suck it!
I bought direct from Fobo. Honestly, once they're installed and you start riding, you hardly notice them again.
Trust me - get the tee fittings and install them with those. Makes filling tires 100 times easier than removing the Fobo every time you want to adjust pressure.
Old Apr 10, 2019 | 11:16 AM
  #54
azgrumbles's Avatar
azgrumbles
Originally Posted by Ultra 99
I believe the sensors are around $100 each. I had a lot of other work done so I can't pinpoint the cost of the flash. It shouldn't be very much,
I called my dealer but I guess they haven’t done it yet. They’re looking into it.
Old Apr 10, 2019 | 10:45 PM
  #55
RiderX's Avatar
RiderX
...Some say you can't enable the TPMS on non-CVO models, but luckily I had a tech who was willing to think outside the box and made it work quite easily. From what I understand, it's easier to do on 2017 and newer models.
When you say he thought outside of the box what do you mean? Was the difficult part flashing the radio or getting the sensors installed / working? What solution did he actually implement?
I have a 2017 Street Glide Special and am interested in adding it to my bike.
Old Apr 10, 2019 | 11:24 PM
  #56
yzernie's Avatar
yzernie
Originally Posted by eaglefan1
HD wants to stay true to what's made them what they are. Simple, reliable bike.
I laughed so hard I almost shart myself. LOL
Curious what you find out. After having my CVO, I want TPMS on this FLTRU and I like the CVO platform for that. Would be easy to add during a tire change.
Old Apr 11, 2019 | 01:51 AM
  #57
ratpick's Avatar
ratpick
Originally Posted by rnl_1200C
slow leaks and high temps can be caught before a blowout. At least you would be able to limp or ride to a service station. At the very least, stop riding before the major blowout occurs, and pull over and wait for service.
Thanks for making this point. Tires almost always blow out from being run at too low a pressure, so TPMS can absolutely prevent a catastrophic failure whether because of a puncture or slow leak, or just failure to check pressure and add air periodically. That said I certainly wouldn't use anything that replaces valve caps since that isn't how valve stems are meant to seal, but I like the look of the orange based system from http://www.rrrtoolsolutions.com
Old Apr 11, 2019 | 05:44 AM
  #58
Ultra 99's Avatar
Ultra 99
I don't think any part of it was difficult. It's just something that was never done before at the dealership and it's not something HD makes known that it can be done on non-CVO's. The parts guy tried to say that there was something else special needed that the CVO bikes had, but the tech checked into it himself and found it could be done quite easily with just the sensors and a flash. Maybe depending on which wheels you have there could be sensor fitment issues, but I don't know for sure. In the case of my Agitator wheels it worked out fine.
Old Apr 11, 2019 | 08:48 AM
  #59
Ssitruc's Avatar
Ssitruc
Maybe give them the name of the dealer that you had yours done at, so the guys could ask their local dealer check with them on how they did it?
I am on a 2016, I have the Orange Electronics set up and happy with it, so I'm sticking with it... but if I had a newer bike I would be checking into this too.
(2014-2016 requires the BCM to be changed also, added expense!)
Old Apr 11, 2019 | 09:06 AM
  #60
peddler's Avatar
peddler
Ssitruc: Where do you have the TPMS monitor mounted on your bike? Pic?
