Changing tires (DIY)
Old Apr 12, 2019 | 09:21 PM
internet troll's Avatar
internet troll
Are you guys using an old school bubble level to balance them? I changed tires all thru college so Im no stranger to tire lube and breaking beads, but balancing concerns me.
And, just so I can say I added to this thread, make sure you remove the valve core when inflating and seating tubeless rims. Makes the job go a hell of a lot faster.
Old Apr 12, 2019 | 09:31 PM
dawg's Avatar
dawg
I use beads or ride on. You can get/make a cheap balancer if you don’t want to go the beads or ride on route. HERE is a cheap one for $40
Old Apr 13, 2019 | 08:08 AM
xcbullet's Avatar
xcbullet
I been doing it a while. Use the board & bumber method to brake seal. Just found something I like is spray on wax for tire lube my rear tire aired up instantly. It's nice to take the time to polish the rims inside and out, just use Scotch Brite red on the inside, never have leaks.
Old Apr 13, 2019 | 08:39 AM
leon anthony's Avatar
leon anthony
I use the beads I just put a bag of them in the tire before I put it on the rim the bag goes away in the first mile or so. No trying to get them all down the valve stem
Old Apr 13, 2019 | 09:10 AM
dawg's Avatar
dawg
I’ve always opened the bag and poured them in before seating the bead. You don’t open the bag and just throw them in? You can also reuse the beads, easy to roll the tire with a piece of paper inside to collect the old beads should you have forgotten to purchase new beads!
Old Apr 13, 2019 | 05:22 PM
Musician's Avatar
Musician
Default tire mounting
Originally Posted by Brewmany
I put my own tires on the Limited a couple years ago- it wasn't all that hard. Put in the T stems for my FOBO TPMS, and used RideOn for balancing. I also replaced my brake pads at the same time, front and rear.
I'd do it again- I had to spend maybe $50 on the tire irons, rim protectors, etc........ But figure not paying HD to do the job more than offset the cost of the tools. Not to mention that I got tires I like better than what I'd have got from the HD dealer- we don't have many independent mc shops around here that I know of, and from what I've heard, many shops won't install customer supplied tires.
I needed a valve stem installed. Guy at the local dealer said 20 to 40 bucks. I wanted a specific answer, not a 20 percent range. Called me back, said 90 bucks. to install a stem, and that's with me bringing in just the wheel. I bought two new stems for a total of three bucks, used my hydraulic press to break the bead, and had the new one installed in less than 5 minutes. No wonder I don't do more than buy parts there.
Old Apr 14, 2019 | 06:20 PM
Goose_NC's Avatar
Goose_NC
Something I was shown years ago. Remove tire from rim, remove all weights clean wheel, check bearings, the balance rim without tire. Mount tire ensuring to line up valve stem and the dot on the tire. Running Metzler and Dunlop tires, I rarely add more weights, but sometime have to adjust the seating of the tire to move the dot an inch or two around the valve stem.
Old Apr 14, 2019 | 07:09 PM
16FXDLI's Avatar
16FXDLI
I agree with most of the above recommendations. I initially bought a kit with two tire irons and it didn’t take long to realize that having a third iron makes the job a whole lot easier.
Old Apr 14, 2019 | 08:37 PM
skydude426's Avatar
skydude426
Yes, three tire irons is a must.
Old Apr 15, 2019 | 02:45 PM
Crabchuck's Avatar
Crabchuck
Originally Posted by EdwardK
I'm surprised no one has mentioned about lining up the yellow dot with the valve stem. The yellow dot on the tire marks the light spot on the tire for balancing. This should be mounted at the heavy spot on the wheel. Almost always the valve stem.
I always throw my rims on the balancer the first time I change them and put a dot inside the rim for the heavy spot. The stem is the heaviest is a good rule of thumb, but not perfect. Also, I use a china marker to write the wheel direction before I take it off. If you do the 90 degree stems, then those are a good indicator too.
11. Clean all the old rubber off the bead surface before mounting a new tire.
