I agree with most of the above recommendations. I initially bought a kit with two tire irons and it didnt take long to realize that having a third iron makes the job a whole lot easier.
So, do you or anyone else have any recommendations on whose tire irons to use? I see a lot of them on Amazon, but I'm not sure which ones to choose.
I use the irons you get a harbor frieght to get them off. They work great. I use a three piece spoon set to get them on. For me the irons are great for removing but the 3 spoon set is perfect for mounting. For my first set I just cut up a laundry jug and used the plastic peices to protect the rims and that worked pretty good. My next time around I ordered rim protectors and they're nice in that they grab and have strings in case one slips off and falls inside the tire while your mounting. I also used tire lube from the local auto parts store to help slip the tire on and off. When it dries it helps seat the bead. A hair dryer is also helpful if you don't have enough warm sun to heat things up.
The No-Mar tire spoons that came with my machine are really good. Unfortunately, they also seem to be expensive. I've sometimes found it easier to use the spoons to install a rear (180/65B16) HD tire on a rim.
I have a no mar tire changet and love their tire spoons
I change my own tires also, I use Pex Water line as rim protectors. I use a 6 long piece with a slit cut in it length wise wide enough to get over the edge of the rim.
Just another inexpensive tool fwiw.
The pex is a great idea. I'm going to keep an eye on the construction sites near me.
I use the Moton Pro 15" curved irons. I had them nylon dipped, but after a few uses, that started to come off. I don't think it was a hard enough nylon. But, they do the job.
What do you guys use to seat the bead? I had a trip to hell and back and still couldn't do it. My local Mavis did it for free and they had a hard time with the front tire.
I am going to keep doing this as needed but need to figure a way to seat the tires. I tried everything under the sun with no luck.
Used a two inch rachet strap last tire. Before that nothing instantly took air. Had one I had to take in once and like you he said it was hard one for him even though don't think it took him 10 minutes.
