Lowering a Road King (Shock exchange)
Old Apr 15, 2019 | 10:39 PM
millcreekdr's Avatar
millcreekdr
Default Lowering a Road King (Shock exchange)
I have read a handful of methods to lower by an inch.
From what I understand, the RK has 12" rear shocks.
  1. Lowering blocks.
  2. Exchanging with 11" SG shocks.
  3. Getting a new suspension front/rear all together
  4. Getting bitchinbaggers to cut down your shocks (exchange program)
I am right at 6ft and feel the stock height should be right on. However, when I am stopped (even with my old lady on the back), I feel it is just a bit high. I have a stock seat and stock shocks.
I don't feel like putting a ton of money into something that is just a hair off. I read they blocks sometimes make it to where you have to alter the hard saddle bags.
Best method is to find someone to trade SG 11" for the RK 12" shocks. Again, without spending a ton of money.
Thoughts?
Thanks.
Old Apr 16, 2019 | 05:46 AM
EdwardK's Avatar
EdwardK
Road King should be 13" shocks stock. Shorter shocks should be a plan of last resort in lowering a bike, The ride quality is terrible on shorter shocks and your old lady will be pissed. Keep in mind she sits right on top of the shock mounts and will feel every jarring little bump in the road. First I'd look at thicker soled boots. 2nd, look at a custom seat builder. Tell them what you want and they can give you a seat that's a little lower and narrower and even better, it will be way more comfortable for both you and the old lay. Stock seats suck in my opinion. If that doesn't work, then maybe, maybe lowering blocks.
My ultimate suggestion is to get used to it. I'm 5'8" with a 30" inseam and my RKC is perfect and I'm also comfortable on my Limited. Both full stock height. If you can back the bike without struggling, sitting at a stop light you should be fine. Even if your not flat footed. I rarely stand flat footed and have no issues. Keep in mind that you spend 99% of the time with your feet on the floorboards. Don't sacrifice ride quality for the 1% of the time you are stopped at a light.
Good luck!
Old Apr 16, 2019 | 05:47 AM
Slowpoke62's Avatar
Slowpoke62
My 2010 RK had 13inch stock shocks. I purchased one of the 1-3inch lowering blocks to see what suited me. I ended up getting the 12 inch aftermarket, progressive 412 shocks with the standard spring. Harley does sell a 12-inch version of the stock air shock that will fit your RK. I did find the 2-inch lower position fine except it let my new headers hit in some turns. You also need to remember the lower you go the stiffer the ride in most cases.
bklynbob's Avatar
bklynbob
Have mean city cycles do a super narrow and lower the seat an inch.
Old Apr 16, 2019 | 07:45 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I've got a pair of SG shocks hanging in the shed. Every once in a while I'll put them on. I do like the better footing, but dislike the ride quality reduction more.
I'll also suggest going with a different seat instead. There are many out there to chose from.
Old Apr 16, 2019 | 05:30 PM
millcreekdr
Thanks. I suppose I will get used to it. Maybe gain 10 to 20 lbs to drop it. It's not terribly high, but I was hoping for a fine tune adjustment to lower it. That not being an option, when I have money to spend, I will look into the alteration of the ride or the upgrade of the seat. I will also look up mean city cycles and see what they have to offer. Appreciate your advice !
Old Apr 16, 2019 | 07:55 PM
foxtrapper's Avatar
foxtrapper
My sg shocks were about $10 at s swap meet. I’ve bought several seats for similar prices. If you can handle used, you can be very cheap.
Old Apr 17, 2019 | 06:36 AM
todd-67's Avatar
todd-67
I strongly agree to try the seat option first. Part of the issue is the stock seats and some aftermarket is that they are too wide in the front forcing your legs out and then down. A narrower seat in that region will gain you quite a bit of leg room. I aquired a mustang 15" solo a while ago and had it on my king until I got a 17" for it. The bike felt about 2" lower with it. My *** is a little too wide for it which is why I switched it out. Going with less travel on the rear really hurts the ride quality.
Old Apr 17, 2019 | 10:11 AM
Peter Quinn's Avatar
Peter Quinn
Just buy a set of Tamarak 1" bolt on lowering brackets for $60 or less...30 minutes work to lower seat inseam height by 1". No change to shock travel or comfort.
Wife will love you and you will still have plenty beer money in your pocket!
Old Apr 17, 2019 | 10:47 AM
BeSharp's Avatar
BeSharp
Agree 100% to keep the 13". I too am 30" inseam on my '09 RK. Changed the seat to a Mustang that's narrower in the front (don't buy one that says "super" or "wide" in the title) and bought a pair of great boots with a bit thicker heel and all is great for me now.
