front sag
Old Apr 22, 2019 | 11:43 PM
KBush's Avatar
KBush
Default front sag
How much rider sag should you have in the front? Setting rear rider sag is a well documented topic but I can't find anything bagger specific on setting front sag. Any imput would be greatly appreciated.
Old Apr 23, 2019 | 05:17 AM
opd1264's Avatar
opd1264
On my race bike 25 to 30 mm is appropriate and on the street a bit more for a plush ride, say 30 to 35 mm. However we have no preload adjustments on the front. Different springs or shimming is required. Initial measurements should be from a fully extended fork then with rider and gear on the bike.
Old Apr 23, 2019 | 06:24 AM
grbrown's Avatar
grbrown
Wink
I have set sag on the forks of my Sportster, which conventional wisdom says should be the same as shocks, namely 1/3rd of total travel. I used Race Tech single-rate springs as the basis, then made spacers to get sag just right.
My Glide is much older than yours, so it would be worth checking your bike's spec to confirm its total fork travel - mine is a little over 4" IIRC, so sag is around 1 3/8".
Old Apr 23, 2019 | 06:26 AM
packmen21's Avatar
packmen21
+1
Old Apr 23, 2019 | 11:59 AM
DanHappy's Avatar
DanHappy
Were talking bike front ends right and not...
lol
Old Apr 23, 2019 | 12:22 PM
Kingface's Avatar
Kingface
lol
HAHAHAHAHA!!!!!!!! I thought this was going to be a 'I'm getting old, is this normal' thread..... HAHA!
Old Apr 23, 2019 | 12:35 PM
grbrown's Avatar
grbrown
Talking
There's only so much can be said about forks...…
Old Apr 23, 2019 | 12:36 PM
KBush's Avatar
KBush
thanks for all the replies, I have the JRI front cartridges upfront and I currently have 1&1/2 inches of sage I was wondering how that compared to others.
Old Apr 24, 2019 | 04:25 AM
grbrown's Avatar
grbrown
Talking
Sounds a little high, unless your forks have 4.5" travel (3 x 1.5"), but if it rides fine, then don't disturb it!
Old Apr 24, 2019 | 04:52 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
The whole object of sag setting it to keep you in the flexible range of the suspension. IE, not bottoming out, nor topping out. As long as it's working, you're good.
Jayhawkhuntclub
13
Apr 21, 2017 05:10 AM
Mchad
Apr 21, 2016 12:10 PM
baka1969
Sep 8, 2013 07:16 PM
Howler_LI
Dec 4, 2012 01:00 AM
Saddle123
Dec 3, 2012 08:56 AM
