Won’t pass fall away test
Start with steering centered and tap it one way. It should start to fall away on its own somewhere between 1” & 2” off center. It won’t swing left or right on its own. Front end should be off the ground and clutch, throttle disconnected so as not to induce any impetus or drag.
Neil
RDMC
I did pack the bearings before installing them and filled the neck until it came out the bottom. My dad was helping me and thought maybe the grease was thick because it was cool out, ~50.
Fall away 1- I believe it was my '12 Limited that had the "start at full left, let go, and it should do two full swings & one partial swing" test. I got that one really close.
Fall away 2- I just did my '01 Springer a couple months ago, it used the "start to turn the wheel from center and measure how far it moves before it falls away on it's own" test. I couldn't get the measurement they wanted, so I did it the old fashion way. I tightened it until I could feel slight binding, and then backed it off until the binding was gone. I checked it for looseness and wobble, and then it felt really good on the test drive, so I believe I got it close. I later realized I messed up the measuring method.... go figure...
OP, if you are using the multi-swing method, I would double check to make sure something isn't impeding the movement of the front end or adding weight to an area where nothing was mounted from the factory. There may be something you forgot to disconnect, something that is rubbing/making contact with the front end that shouldn't be touching it, and/or something affecting the original OEM balance. Start with any aftermarket stuff you may have added to the instrument area or handlebars.
Good luck, and you could always do it the old fashion way....
NOTE: When using the not too tight, and not too loose method, don't give the neck bearings too much preload.... better to be on the loose side than the tight side... if too tight, the bike will be hard to balance at slow speed and the steering will feel heavy....
I still have the entire fairing off so nothing is influencing it there. The only thing left hooked to the handlebars is the brake line
( 2 )
It may be best to call a dealer and ask them if the adjustments for your 04 were changed threw a TSB.
