Oil temp sensor
Old Apr 28, 2019 | 10:16 AM
Dragon2c's Avatar
Dragon2c
Originally Posted by hdbob2006
I see 2 non stock wires,on the frame down tube above the oil filter. 2 beige wires with solderless connectors into 2 green wires. did you trace those down,to see where they go?
They are connected to my siren speaker
Old Apr 28, 2019 | 10:20 AM
Dragon2c's Avatar
Dragon2c
Originally Posted by skinman13
I recently installed the HD oil temp kit ($127 from Surdyke). I have seen the oil pan oil temp as high as 230 F, indicated, after hard runs. It typically runs between 180~200, more or less. I made a 200+ mile ride yesterday and the temp was hovering just below 230 F when I got home after a hard 25 mile run at 75 - 85 mph on the Sam Houston Tollway. I am interested to see how high it gets during our infamous Texas Gulf Coast summers...
That is the main reason I was looking at the install instructions. I just recently moved back to SC and we have all ready hit 90 deg days that's the average day in PA. I was running around 230 to 240 on the highway little more in town with traffic.. when I asked the dealer what the normal safe range is they told me they didnt know. With the temp it can reach down here just want to know what is safe. I am getting an oil cooler in a few weeks
skinman13's Avatar
skinman13
Originally Posted by Dragon2c
It is a harley gauge.
The install instructions say to mount the sender in the pan unless you have the older model system that mounts the sensor in the oil line shown above. You can get the install PDF from the HD sales site...pull up the system and look for the documents tab.
A photo of the gauge you are concerned about would help answer your question...
Old Apr 28, 2019 | 10:26 AM
Dragon2c's Avatar
Dragon2c
Old Apr 28, 2019 | 05:53 PM
Dragon2c's Avatar
Dragon2c
Old Apr 28, 2019 | 06:19 PM
soos's Avatar
soos
Hey OP, didja look behind the cover to see if that is where your sensor is?
Old Apr 28, 2019 | 07:00 PM
IKnowNot's Avatar
IKnowNot
Don’t know if this is what you are looking for, but go to the harley site
https://serviceinfo.harley-davidson.com/sip/index
and put in a search for
75265-04
That will bring up instructions for one of the gauges that don’t mount the sending unit in the oil pan.
Old Apr 28, 2019 | 09:23 PM
Dragon2c's Avatar
Dragon2c
I had to go out of town to work on my sisters truck. I'll check the cover tomorrow.
Old Apr 29, 2019 | 03:12 PM
Dragon2c's Avatar
Dragon2c
Looks like it was behind the cover. Thanks for you'll help
Old Apr 29, 2019 | 06:15 PM
soos's Avatar
soos
Mystery solved. Pretty tight quarters.
