Forks won't lock on 88 FLHTC
Old May 6, 2019 | 10:33 AM
BroWebb's Avatar
BroWebb
Default Forks won't lock on 88 FLHTC
Guys, New owner of a 88 FLHTC and for some reason my front forks will not lock. My key assembly will function and the lock will engage when I turn it to the lock position but the front forks will not lock down no matter what it try. I am not sure if it is a issue with the key assembly or the locking mechanism itself. Any help would be great.. thanks in advance.
BroWebb
Old May 6, 2019 | 10:41 AM
Silentgreyfellow's Avatar
Silentgreyfellow
Do you have the handle bars all the way to the left when trying to lock it? If so maybe try some penetrating oil in the lock mechanism.
Old May 6, 2019 | 10:59 AM
Mountainkowboy's Avatar
Mountainkowboy
There is an adjuster at the switch, mine did the same thing
Old May 6, 2019 | 11:54 AM
BroWebb's Avatar
BroWebb
Can you give me any instruction of the location on that adjuster? Pics?
Old May 6, 2019 | 02:05 PM
Mountainkowboy
There is a "paddle" inside the cover that the switch operates via a long phillips screw with a spring and washer on it, it's adjusted by turning the screw, which changes the throw of the paddle. You may be able to get to it by removing the headlight bucket and it may be put together wrong...the spring and washer may be in the wrong place to operate the lock properly. This is the only pic I have of the fork lock assembly, it's under the "box" that's circled in the pic and the switch sit in front of it and pushes the lever when locked...it should cover adjustment in the service manual. If you dont have one, I suggest you get one, the information is invaluable and covers dang near everything about them.
Hope this helps
usmc68
Sep 19, 2017 06:57 AM
supermanotorious
Nov 3, 2013 01:21 AM
timbo8
Jul 15, 2010 08:08 PM
TheGent
May 3, 2010 08:43 AM
HDF Tech
General Topics/Tech Tips
Aug 12, 2005 09:29 PM
