I just ordered a set of 14" Wild 1 Chubby apes for my Road King. Now looking to order a complete cable and wire install kit.
Looking for suggestions from those that have used a complete install kit. I'm leaning towards the Magnum shielding kit but kinda pricey at almost $500.
I just did a 14" install about a month ago and went with the Magnum kit. Worked perfect, I searched around and actually found the exact kit I needed on ebay for $120! It was brand new at a shop. Someone ordered it and never picked it up, got lucky! Once you find the kit you need write down the item # and do an ebay search.
I installed HST 1-1/4" Mayhem 14" bars. I rerouted the wiring as they show in the video, but did not need to reroute the cables.
Wiring these was a pain in the butt though! In the video they suggest you remove the connector housing on one side (re-installs easily)... I tried for 2 hours without removing the connector housing, and finally had to. If you avoid the "demon peaked" bars, you can probably get away without removing the connector.
