Wheel swap?
Old Jul 9, 2007 | 11:12 PM
cmose's Avatar
cmose
Default Wheel swap?
Does anyone know if it is possible to put wheels from a 2005 Road King Custom on a 99 Road King? I have a friend that wants to sale me his tires,wheels,pulley, and rotors. I was told to have the bearings replaced w/ 3/4 inch and they should work.I think the rear is the same.
Old Jul 9, 2007 | 11:20 PM
Bryan1724's Avatar
Bryan1724
Default RE: Wheel swap?
Yes you can even though the 99uses 3/4" axles and the wheels you would be putting on use 1" axles. Talked to a HD wrench and he said they sell a kit to do it. Or you can go out on your own and size em up. It's just a matter of getting the right bearings to fit the wheel huband a 3/4" axle. Also if you are going to do it on your own, please make sure you get high speed bearings. Aand yes I'm in the process of doing this myself. My 03 Road King wheels will be here today when I get home from work. I'm converting my 99 front end over to a 06-07 style without the cartridge in the fork. Still in the early stages, and have a long way to go yet. [:@]
Old Jul 9, 2007 | 11:25 PM
Bryan1724's Avatar
Bryan1724
Also forgot to mention you need new rotors too.
Old Jul 10, 2007 | 07:13 AM
cmose's Avatar
cmose
He is selling me the rotors and pulley also. Do you know where I can buy the kit?
Old Jul 10, 2007 | 04:33 PM
Bryan1724's Avatar
Bryan1724
ORIGINAL: cmose
The guy at Laugerman's HD in York PA says that they sell them so I would guess any HD shop will have them or can get them.
Old Jul 10, 2007 | 04:42 PM
Bryan TTM's Avatar
Bryan TTM
its a common sealedbearing....just need the internal spacer...HD has them too....aint no big deal to do
Old Jul 10, 2007 | 06:23 PM
Biggzed's Avatar
Biggzed
I thought I read somewhere that the new style rotors are not compatible with the old style calipers. I can't for the life of me think of a reason they wouldn't work, but it's probably worth doing some research.
Old Jul 10, 2007 | 06:26 PM
Biggzed's Avatar
Biggzed
Your internal spacer from your old wheel should work. If you want an extra one, so you can sell your old wheels complete, I think I have one. Shoot me a PM with your address and I'll mail it to you. No charge.
Old Jul 10, 2007 | 10:11 PM
cmose's Avatar
cmose
One other thought. Does anyone think the pulleys are different. I know they are both 70 tooth but are the differnt thickness. The other bikes belt is narrower than mine.
Old Jul 10, 2007 | 10:34 PM
Biggzed's Avatar
Biggzed
I think they went to a narrower pulley when they went to a 150 rear tire. I would plan on using your old pulley.
Bottom line is, you should measure everything before bolting things up.
Blighty
Wheels/Tires
Oct 31, 2014 08:46 AM
Karen Nixon
Wheels/Tires
Nov 15, 2013 01:21 AM
jbwftx
Wheels/Tires
Oct 29, 2010 04:54 PM
MrHog
Wheels/Tires
Jul 8, 2010 04:43 AM
hurstt
Jun 19, 2006 03:56 AM
