I WANT MORE POWER!
Old Jul 10, 2007 | 09:25 AM
jmistichelli's Avatar
jmistichelli
Stage II
Default I WANT MORE POWER!
Folks,
I wanted to get some input as to what air cleaner and exhaust combination would yield me a high amount of HP boost. I have an 07 Ultra Classic and want to do it up right. Any info is appreciated. Thanks in advance.
John
Old Jul 10, 2007 | 09:35 AM
Retired_Ted's Avatar
Retired_Ted
Default RE: I WANT MORE POWER!
A good start is the SE air cleaner and a good set of slip ons - like V&H Ovals. That'll get you about 5-10 HP - you will need a fuel management system, however, such as a Power Commnader or a SERT (Screamin' Eagle Race Tuner) plus a dyno. You'll end up paying anywhere from $100 to $150 per HP.
Old Jul 10, 2007 | 09:38 AM
nidan's Avatar
nidan
SERT and a stage 1 will get you a little bump, I just had the 103 Stage II with SE street perf. slip-ons installed , only 250 miles but I think this is how all the touring models should come.
I've ridden the CVO 110's and this isn't substationally different ( same cams) . The upgrade is relatively cheap compared to the 88-103 . I'd certainly recommend it .
Old Jul 10, 2007 | 09:45 AM
LOU's Avatar
LOU
There are several stages you can use to improve the preformance on your bike. I went with Reinhart True Duals, SE Race Tuner and an Arlen Ness Big Sucker (replacing the stage one w/slip ons that came with the bike) to start with a big improvement over stock. In fact; it runs so good right now I may not do anything more on the preformance end for awhile.
Old Jul 10, 2007 | 09:59 AM
Douce48's Avatar
Douce48
John,
I just went through what your looking to do. Look at my signature for what I put on. The throttle response is 'sick quick' over stock.
I couldn't believe the RPM range how much it opened up between shifts.
The V&H ovals sound awesome at idle, cruising and throught the range of shifting. Their a little loud for me though when the bike is under demand, generally going up hills.
Unfortunately, I now have a oil leak and it's going in Friday for repair (nothing to do with mod's)
Good Luck,
Douce
Old Jul 10, 2007 | 11:49 AM
LowriderFXRS's Avatar
LowriderFXRS
I have the same setup as Douce48 on my '07 FLHTC except I went with the K&N intake system. It runs very healthy.
Old Jul 10, 2007 | 01:02 PM
dagnabit9's Avatar
dagnabit9
I went with the Arlen Ness Big Sucker A/C kit, with V&H oval slip-ons and V&H FuelPak. Big difference in low end torque and overall power and performance. Had a small problem with pinging on light acceleration (going up hills and such), but a quick call to V&H tech support fixed that. Cost was a little over a grand. You won't be disappointed...
Old Jul 11, 2007 | 01:00 PM
jmistichelli
Stage II
Thanks guys. I really appreciate the input.
John
Old Jul 11, 2007 | 01:44 PM
the_icemAN's Avatar
the_icemAN
have the Screamin Eagle A/C.... the V&H Fuel Pack and the Rinehart True Duals. LOVE IT.... LOVE IT... and really LOVE IT.
$130 for the SEAC
$225 for the V&H FuelPak
$695 for the RH TDs
$1,070 for the Stage 1 setup I did.
Toe Knee
Apr 5, 2015 11:10 AM
dafuzz89
Exhaust System Topics
Apr 12, 2014 07:03 PM
Guitardude
Mar 22, 2013 10:01 AM
tully_mars
Aug 26, 2010 08:47 PM
JW
Oct 24, 2005 03:48 PM
