Wobble
Old Jun 6, 2019 | 08:39 AM
eaglefan1's Avatar
eaglefan1
Originally Posted by GalvTexGuy
Based on all I know now, I'm going to say it's the tire. My handlebars wobbled like that at about 45 MPH when I took my hands off. New tire fixed it. Here's a video:
https://youtu.be/cgY3tlm1rIE
That is almost exactly what mine did. Was the tire cupped?
Old Jun 6, 2019 | 08:43 AM
GalvTexGuy's Avatar
GalvTexGuy
That was with the original factory tire, so I'm going to say yes, it was cupped.
Old Jun 6, 2019 | 10:40 AM
eaglefan1's Avatar
eaglefan1
Just did the swing test. Pulled bars all the way left and let go. 6 sings until it stopped. Bars to the right 7 swings, #7 was just a tiny bit.
Tire had 39 1/2 of air, avon says 40lbs
I guess its a neck bearing adjustment. Grease it before or after?
Old Jun 6, 2019 | 07:11 PM
preacherbo's Avatar
preacherbo
I had the "wobble of death" years ago on my Honda VTX. Scared the pee-waddlings out of me. It was a tire issue. I had gone to the Dark Side. Never again.
Old Jun 6, 2019 | 07:17 PM
eaglefan1's Avatar
eaglefan1
Ill be buying the bearing adjustment tool. Hopefully this fixes the issue
Old Jun 6, 2019 | 07:27 PM
chopper_man's Avatar
chopper_man
Did you check your tire for cupping? Open hand, and run it both directions along the treads. If you feel an "edge" in one direction it is cupped and the cause of your issue.
Old Jun 7, 2019 | 06:28 AM
danzio's Avatar
danzio
Most likely you're going to go through all that with the neck bearing and still have the problem. It's almost certainly the tire or wheel. In my case the bike developed the death wobble only after I had put the tour pak back on after being in solo mode for a long period of time. The bike never showed any signs of a wobble until then. Shortly afterwards I needed to replace the tires. No more wobble and it's been great ever since, about 8,000 miles.
Old Jun 7, 2019 | 07:08 AM
GalvTexGuy's Avatar
GalvTexGuy
You could take off the tire/rim and check the balance with a homemade tire balancer. I've never heard of tire/rim not needing weights when checking balance.
Old Jun 7, 2019 | 07:37 AM
eaglefan1's Avatar
eaglefan1
I was there when he mounted and balanced the tire. He actually spun the tire twice in the machine because of it.
Might be a good time to add Ride On?
So the consensus seems to be the tire is bad along with the neck bearings needing adjustment?
Old Jun 7, 2019 | 08:15 PM
xcbullet's Avatar
xcbullet
I would for sure ajust the neck bearings that's way to loss. I ajusted mine with out a tool, used a piece a metal had that was 1/8 thick. Was able to get in there and tap it around. Think I had to take radio out to get to it. Grease it first , if you don't it might get loose after greasing it. Probably best to grease it ride it then ajust it.
