Need help finding Replacement bearings
Old Jun 18, 2019 | 03:34 PM
Uncle Larry's Avatar
Uncle Larry
A big congratulations on the boy ( now he's a man for sure ) graduating from basic ... I did the same thing, about 50 years ago :>)
Old Jun 18, 2019 | 03:37 PM
SFinley70's Avatar
SFinley70
That’s exactly what i told him. I told him now you are a Man and how proud i was. I actually graduated basic at Ft Leonardwood in 1987 and was really Proud to see my youngest to do the same thing. My middle boy also graduated from there in 2011..Thank you and Appreciate your service Brother
Old Jun 18, 2019 | 03:52 PM
big- mike's Avatar
big- mike
Check your primary chain adjuster mine over tighten the primary chain and I believe that’s what took out my main bearing like yours my first indication was my drive belt was rest tight. Adjuster pulled everything forward and took out bearing
Old Jun 18, 2019 | 03:59 PM
SFinley70's Avatar
SFinley70
I changed all that last summer to a Baker Compensator and a Baker Attitude chain adjuster. Before i changed those though my chain was so tight from the automatic adjuster. Im sure my bearings problem came from before the Baker Comp/ Adjuster change but didn’t notice anything leaking until after this recent trip. Like you i also think the automatic adjuster caused most if not all of the issues i have. My gf did notice some weird vibration on passenger floorboards during our trip so i bet what she was feeling was the bad bearings.
Old Jun 19, 2019 | 08:37 AM
big- mike's Avatar
big- mike
How did you make out?
Old Jun 19, 2019 | 09:20 AM
SFinley70's Avatar
SFinley70
Ordered bearings so gotta wait until they arrive Friday before i can put it all back together. When you changed yours did you replace with the 8967 double row bearing or the revised 8967A single row bearing which looks to have 11 bigger bearings but only single row?
Old Jun 19, 2019 | 05:54 PM
big- mike's Avatar
big- mike
Mine is a 2010 and it had the double row and that’s what I put in each time I went in there. Be careful when you slide the trans back in I damaged the bearing retainer on the inner bearing on the output shaft. That’s why I told you about removing that race I missed it the first time and couldn’t figure out why it wouldn’t pull back in all the way so I took it back apart and you know every time you do that you need a new bearing
Old Jun 19, 2019 | 06:17 PM
SFinley70's Avatar
SFinley70
I also bought the double row bearings . I may get lucky and bearing be here tomorrow ( tracking shows at local hub)so probably tomorrow evening once it gets cooler out i will start putting it all back together. I appreciate your help here and im just gonna is take my time putting it back together so i hopefully dont make any mistakes
Old Jun 19, 2019 | 06:48 PM
big- mike's Avatar
big- mike
When installing the output shaft seal us a piece of 1” pvc to set the seal in place after you reinstall the trans. And make sure you tape the splines on the input shaft
Old Jun 19, 2019 | 06:53 PM
big- mike's Avatar
big- mike
When you get to the inner primary bearing and seal not to block the oil port it makes note of it in the service manual
