2007 ultra classic 110
Old Jun 26, 2019 | 09:35 PM
Tom Prosser's Avatar
Tom Prosser
Stage II
Default 2007 ultra classic 110
Brake light stays on and neutral light also. The only way to crank out of to take the negative battery terminal lose fire a few minutes and then reattach they it will crank. Previously it would not crank occasionally and you would have to turn the ignition off and then back on then it would crank. New battery in key fob..
Any ideas or suggestions
Old Jun 27, 2019 | 05:16 PM
Zerk's Avatar
Zerk
I could tell you the cure for 96" FLHTCU, but not 110. Just kidding. How about some more details.
Having trouble following. Will not start. Cranks but does not fire? If it cranks over, I am pretty sure not the FOB or secruity. Sometimes will not turn over, unless you disconnect battery? Sometimes run and then dies?
Not sure what you mean about brake and neutral light.
Old Jun 27, 2019 | 05:51 PM
dawg's Avatar
dawg
I would start by checking the codes. How old is the battery and have you checked the connections lately?
Old Jun 27, 2019 | 05:56 PM
Zerk's Avatar
Zerk
Followed by a detailed write up. If it stalling, I doubt bad battery. If cranking at normal speed I would also doubt battery. Agree codes, could be a sensor, but could be fuel, or spark. Hard to tell.
Old Jun 27, 2019 | 06:02 PM
Screamin beagle's Avatar
Screamin beagle
It may be the ignition switch...try turning it slowly just a little bit while hitting the start button. Mine does it after sitting a few,days. It's free to try
Old Jun 29, 2019 | 08:32 PM
Tom Prosser
Stage II
Thank you for your help...removed the switch, cleaned terminals and contact points and it starts everytime more.
coolbrze
May 13, 2019 09:29 AM
mach1dmb!
May 10, 2017 01:03 AM
opghost
Oct 17, 2013 11:47 PM
Wezdog
Feb 20, 2013 05:06 PM
kenny1234565
Jul 27, 2012 08:21 PM
