Breather hose routing
Old Jul 2, 2019 | 06:57 PM
goldie's Avatar
goldie
Default Breather hose routing
Hi all,
Happy 4th to all! To those folks who are running vent to atmosphere setups, does it make a difference if you route the hoses up and over front cylinder past regulator on to belt guard versus running straight down to Y under throttle body then to ground? I ask because my discrete breather from DK was leaking. I spoke with them and have since added Teflon tape to breather bolts. As I r&r the bolts I notice clean oil in those bolts as opposed to the brownish slim I've seen come out the bottom on my old 99 RKC. Bike is a 2015 RGS stage 1. It's was vented to ground at 5k the up & over route, 40k now. I've seen water drip out breather hose in cold weather when I was warming it up but never left the oil slim spot that the RKC would leave after running hard..
Thanks......goldie
Old Jul 2, 2019 | 07:18 PM
dawg's Avatar
dawg
I’ve always routed mine down to a T then down to the ground. I don’t like the idea of going uphill
Old Jul 2, 2019 | 07:23 PM
acchd's Avatar
acchd
Here's pic of mind to give you idea.
Old Jul 2, 2019 | 07:33 PM
xcbullet's Avatar
xcbullet
I like both sides to be separated. They come out the front of box. I used to have them wrap across the front tubes then down and that didn't stand out but one of them didn't drain well so did this. As u can see on the ground they both have a spot. This is in cooler weather. When hot doesn't leave spots everywhere.
Old Jul 2, 2019 | 07:41 PM
SG-Jay's Avatar
SG-Jay
I have mine up under the gas tank and down to the ground beside the fuel overflow. It's been this way for years with no issues. I started a thread about it.
https://www.hdforums.com/forum/touri...ther-tube.html
sandman88
Jun 11, 2016 09:39 AM
dpoll995
Oct 11, 2015 03:32 PM
MachU
Aug 23, 2013 09:55 PM
aklim156581
Feb 12, 2012 08:57 AM
128auto
May 31, 2007 05:29 PM
