EPA Nonsense
Old Jul 6, 2019 | 11:14 AM
  #61
harkon's Avatar
harkon
Originally Posted by skratch
name one carb compliant tuner other than the hd sepst.
FP3 C.A.R.B.
https://www.revzilla.com/motorcycle/...rley-2011-2017
Old Jul 6, 2019 | 11:37 AM
  #62
skratch's Avatar
skratch
okay, let me rephrase that a little. name one carb compliant tuner for the milwaukee 8 engine....
Old Jul 6, 2019 | 12:16 PM
  #63
otto.maddox's Avatar
otto.maddox
The end result is the dealer and Moco have to prove the changes you made caused the warranty issue.
Old Jul 6, 2019 | 12:35 PM
  #64
NMfxdf's Avatar
NMfxdf
Prove to who? You? Me? the average Joe biker? If any manufacturer denies your warranty and you ask them "prove to me it was x part" they will laugh at you. The legal bills you will have to pay to make Harley Davidson prove to you that the problem was your fault will be more than the cost of the initial fix.
Old Jul 6, 2019 | 12:46 PM
  #65
smitty901's Avatar
smitty901
copy of other post
Old Jul 6, 2019 | 12:47 PM
  #66
smitty901's Avatar
smitty901
Originally Posted by foxtrapper
Warranty is Harley, not EPA. Nonsense generally is dealers disregarding the Magnuson-Moss Warranty Act. Again, not EPA.
That said, modifications can indeed void parts of your warranty, even with oem parts. Read the terms of your warranty. If you're truly worried about voiding sections of your warranty, leave it stock until the warranty runs out.
Putting out bad information. EAP put heavy fines and restriction on HD. And is watching like a hawk. The old Magnuson act is all but dead when it comes to EPA meaningless any more. All your thoughts on the facts do not change that.
Old Jul 6, 2019 | 01:05 PM
  #67
hattitude's Avatar
hattitude
I don't believe that is accurate.. The MM Act is alive and well...
The MM Act requires a written warranty, if a warranty is offered, and prohibits a manufacturer warranty from requiring "any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name".
1) Harley HAS a written warranty. By the way, it lists several "Exclusions" and "Other Limitations" above and beyond was was agreed to in the EPA Consent Decree.
2) Harley does not REQUIRE (they do recommend) parts "identified by brand, trade, or corporate name" for OEM spec replacement parts (ie: Oil, filters, etc)
The MM Act only applies to OEM spec components...
We are talking about performance enhancing and/or non-OEM spec parts... MM Act has never applied to these parts/use..
Old Jul 6, 2019 | 05:07 PM
  #68
Wildman4x4nut's Avatar
Wildman4x4nut
Originally Posted by harkon
Yes it is C.A.R.B. compliant but did you read any of the reviews of this tuner? It has limited maps for it that will work with aftermarket parts. It isn't the same as other FP3 tuners.
Old Jul 6, 2019 | 06:32 PM
  #69
harkon's Avatar
harkon
Right, it can't be the same otherwise they'd all be CARB compliant. I was only saying it is an alternative to the HD tuner, not better or worse.
I wasn't immediately aware it was not for the M8. Looks like options for those truly are limited to HD.
Old Jul 6, 2019 | 07:44 PM
  #70
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
We’re all shocked in this thread to hear of an EPA fine, and had no idea such a thing took place.
We’re probably all equally intrigued by your claim that the MM act is all but dead, and that the EPA can and does ignore it.
Certainly, a fellow like you, who complains that thoughts aren’t facts, and complains of me putting out bad information will roll out the amassed evidence you have in your possession to substantiate these claims you are making.
i did provide links to the Consent Decree, and to background documents there of. Undoubtedly you will do the same.
